Author Topic: Calculation lisp -help  (Read 1841 times)
PM
« on: January 15, 2022, 03:09:23 PM »
Hi is possible to write a lisp to calculate a sigle text (this text must be anythig with numbers )
 for examle
E1 = (1/2 x 59.328 x 102.361) + (1/2 x 16.672 x 85.953) = 3752.93 sq.m
or
E= 3036.410 + 716.521 = 3752.93 sq.m
Select the text
and insert the calculation.
I get the idia by this photo
Re: Calculation lisp -help
« Reply #1 on: January 15, 2022, 05:05:46 PM »
Wouldn't you just use a table for that need?
PM
« Reply #2 on: January 15, 2022, 05:32:38 PM »
i was thinking if i can do this without use a table, but a single text
BIGAL
  • 40 + years of using Autocad
« Reply #3 on: January 15, 2022, 05:48:54 PM »
There was a post I think over at Forums/autodesk convert formula to lisp, pretty sure for simple x*y x-y x+y x/y that has been done. I think did something
Anyway for autocad users Cal. Note no Cal in Bricscad
Command Cal
1234*456
562704
Command: CAL
>> Expression: (1/2 * 59.328 * 102.361) + (1/2 * 16.672 * 85.953)
You can save the cal into a variable
Command: (setq m2 (cal "(1/2 * 59.328 * 102.361) + (1/2 * 16.672 * 85.953)"))
3752.94
(setq str "(1/2 * 59.328 * 102.361)+(1/2 * 16.672 * 85.953)")
Command: (vl-cmdf "cal" str)
3752.94091
3752.94091
« Last Edit: January 15, 2022, 06:07:02 PM by BIGAL »
PM
« Reply #4 on: January 15, 2022, 06:04:58 PM »
Is it  possible to select the text , if have x instend of  * to understand it and insert a text with the result ?
BIGAL
« Reply #5 on: January 15, 2022, 06:09:39 PM »
Post updated, to allow for a string input.
Yes you will need to replace x with * in the text string when you pick the table text, lee-mac.com/stringsubst.html
PM
« Reply #6 on: January 15, 2022, 06:37:14 PM »
I try this but is not working
  1. (defun c:test ( new old str / inc len )
  2.     (setq len (strlen new)
  3.           inc 0
  4.     )
  5.     (while (setq inc (vl-string-search old str inc))
  6.         (setq str (vl-string-subst new old str inc)
  7.               inc (+ inc len)
  8.         )
  9.     )
  10.     str
  11.   (vl-cmdf "cal" str)
  12. )
  13.
  14.
thanks
It's Alive!
  • Retired
  • AKA Daniel
« Reply #7 on: January 15, 2022, 07:05:09 PM »
not sure how to do this with lisp, but you can create an expression in fields I.e. %<\AcExpr (2*4)>%
I think LM has lisp tools to work with fields
BIGAL
« Reply #8 on: January 16, 2022, 11:50:57 PM »
Still need to convert x to * the others are ok / - +
BIGAL
« Reply #9 on: January 17, 2022, 12:24:51 AM »
The answer is a bit long winded, still need to replace X with *
http://www.theswamp.org/index.php?topic=41681
You need say (setq ans (eval (infix->prefix "2 * 2 * 34")))
BIGAL
« Reply #10 on: January 17, 2022, 12:40:42 AM »
I had problems but this works
(defun rep ( new old / inc len )
 (setq len (strlen new) inc 0)
 (setq str (vl-string-subst new old str inc))
 (setq inc (+ inc len))
(setq str "2+(3x6/4)")
(rep "*" "x")
(princ str)
(vl-cmdf "cal" str)
