Author Topic: SSGET and layernames with brackets  (Read 1011 times)
Peter2
« on: October 01, 2021, 12:09:42 PM »
Maybe it's an old think I have forgotten, but ...
I have layernames which are using brackets, like
  1. (setq layername "my [crazy] layer(name)"
Using a ssget like
  1. (ssget  (list (cons 8 layername)))
always returns 0 elements. Removing the brackets from layername solves the problem.
Is there another (better) solution than renaming?
Peter
BricsCAD V23
Re: SSGET and layernames with brackets
« Reply #1 on: October 01, 2021, 01:22:17 PM »
Since string-valued DXF groups within ssget filter lists accept wildcard operators, you'll need to escape those wildcard operators that you intend to be treated as literals, e.g.:
  1. (ssget '((8 . "my `[crazy`] layer(name)")))
Peter2
« Reply #2 on: October 04, 2021, 08:43:53 AM »
Thanks Lee
works fine now.
Peter
Peter
BricsCAD V23
