Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
is "SOLID" an "Unknown pattern name" ?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: is "SOLID" an "Unknown pattern name" ? (Read 937 times)
domenicomaria
Swamp Rat
on:
June 24, 2021, 03:44:38 AM »
Command:
-HATCH
Current hatch pattern:
SOLID
Specify internal point or [Properties/Select objects/draW boundary/remove Boundaries/Advanced/DRaw order/Origin/ANnotative/hatch COlor/LAyer/Transparency]:
P
Enter a pattern name or [?/Solid/User defined/Gradient] <Solid>:
SOLID
Unknown pattern name.
Solid
>: (I press
ENTER
Enter a pattern name or [?/Solid/User defined/Gradient] <Solid>: *Cancel*
And this happens also via VLISP . . .
Any idea ?
Logged
tombu
Bull Frog
ByLayer=>Not0
Re: is "SOLID" an "Unknown pattern name" ?
Reply #1 on:
June 24, 2021, 07:33:12 AM »
It's already set to Solid but if it wasn't you can set it easy enough.
Code:
[Select]
(setvar "HPNAME" "SOLID")
Logged
Tom Beauford P.S.M.
domenicomaria
Swamp Rat
Reply #2 on:
June 25, 2021, 09:39:59 AM »
. . . it was caused by the fact that there was,
in the support file search path,
a
corrupted PAT file
that I removed . . .
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
