Author Topic: affine transformation  (Read 1108 times)
PM
« on: June 01, 2021, 11:31:49 AM »
Hi .I am searching for affine transformation lisp code. Can any one have one?
BIGAL
  • 40 + years of using Autocad
Re: affine transformation
« Reply #1 on: June 01, 2021, 08:57:19 PM »
There is matrix function lisp examples that is about as far as I can help.
d2010
« Reply #2 on: June 05, 2021, 05:55:14 AM »
You must search otherwise method(for save the matrix)
step1)Anyway. you google "the Best AffineTransformation in Delphi, C# or FreePascal with google Contest.AI"
or other programming language which you understanding.
step2)You downgrade these source(from step1) to math equations.
step3)We need to simulate/emulate the Matrix in newMode.(not classic mode)
step4) .
:cry2: :brow: :yes:
The main problem is the Matrix of Reals. The matrix-Of-Numbers are too slow in Visual-Lisp.If you unknown C# or VBA then you read this.pdf
« Last Edit: June 05, 2021, 06:34:16 AM by d2010 »
