Author Topic: Using list in function  (Read 1452 times)
civil.eng
« on: May 29, 2021, 04:06:56 AM »
Hi everyone,
I'm trying to write a function to populate list items in each popuplist :
(defun setpop ()
(setq poplist (list '("popup1" "alist")
      '("popup2" "plist")
      '("popup3" "plist")
      '("popup4" "slist")
  (foreach pop poplist
    (start_list (car pop))
    (mapcar 'add_list (cadr pop))
    (end_list)
But it gives this error :
; error: bad argument type: listp "alist"
For example "alist" items are :
(setq alist '("Orchard" "Wall" "Pool" "Building"))
Tharwat
  • Hypersensitive
Re: Using list in function
« Reply #1 on: May 29, 2021, 05:04:41 AM »
  1.     (start_list <key_of_popup_list>)
  2.     (mapcar 'add_list (mapcar 'cadr poplist))
  3.     (end_list)
  4.
civil.eng
« Reply #2 on: May 29, 2021, 05:28:11 AM »
Thank you Tharwat, But I don't want to add all cadr item of list to popup list, I want to populate items of realted list in loop , like:
<popup1 > items of alist
<popup2 > items of plist
Tharwat
  • Hypersensitive
« Reply #3 on: May 29, 2021, 05:30:28 AM »
Simply replace cadr with car
civil.eng
« Reply #4 on: May 29, 2021, 05:42:51 AM »
Tharwat, there are several popup lists and lists , and the loop that I have written must populate each list to each popup.
Tharwat
  • Hypersensitive
« Reply #5 on: May 29, 2021, 05:47:30 AM »
  1. (foreach key '("key1" "key2" "key3") ;; add all keys of your popup_lists
  2.   (start_list key)
  3.   (mapcar 'add_list (mapcar 'car poplist))
  4. )
  5.
civil.eng
« Reply #6 on: May 29, 2021, 05:53:36 AM »
Wrong again, that should be like :
(foreach key '("popup1" "popup2" "popup3") ;; add all keys of your popup_lists
  (start_list key)
  (mapcar 'add_list (cadr poplist))
  (end_list)
(cadr poplist) are items of a list like "alist"
(setq plist '("region1" "region2" "region3"))
(setq slist '("riverNG" "riverTH" "riverCR"))
popup1 > alist
popup2,popup3 > plist
popup3 > slist
« Last Edit: May 29, 2021, 06:01:47 AM by civil.eng »
Tharwat
  • Hypersensitive
« Reply #7 on: May 29, 2021, 06:00:45 AM »
  1. (defun setpop (/ poplist)
  2.   (setq poplist (list '("popup1" "alist")
  3.                       '("popup2" "plist")
  4.                       '("popup3" "plist")
  5.                       '("popup4" "slist")
  6.                 )
  7.   )
  8.   (foreach pop (mapcar 'car poplist)
  9.     (start_list pop)
  10.     (mapcar 'add_list (cdr (assoc pop poplist)))
  11.     (end_list)
  12.   )
  13. )
  14.
civil.eng
« Reply #8 on: May 29, 2021, 06:10:08 AM »
Yes this is right, but it shows only item of "(cdr (assoc pop poplist)" , it must show items of each list like "alist"
popup1 > alist
popup3 > slist
Tharwat
  • Hypersensitive
« Reply #9 on: May 29, 2021, 06:22:37 AM »
You should have learned a lot for now from all these different scenarios.  :grinwink:
Be sure to have the variables 'alist' 'plist' ...etc assigned with list of items to avoid errors and failure.
  2.   (setq poplist (list (list "popup1" alist)
  3.                       (list "popup2" plist)
  4.                       (list "popup3" plist)
  5.                       (list "popup4" slist)
  6.                 )
  7.   )
  9.     (start_list pop)
  10.     (mapcar 'add_list (cadr (assoc pop poplist)))
  11.     (end_list)
  12.   )
  13. )
civil.eng
« Reply #10 on: May 29, 2021, 06:30:15 AM »
Bravo, you did great
« Reply #11 on: May 29, 2021, 05:10:52 PM »
The current code is processing the list in the following way:
  • Obtain a list containing the first elements of the original list
  • Iterate over the list of first elements
  • Use the first element to obtain each item from the original list
  • Add the contents of each item to the popup list tile
Instead, you can iterate over the list in a single pass in the following way:
  1. (defun setpop ( )
  2.     (foreach lst
  3.         (list
  4.             (list "popup1" alist)
  5.             (list "popup2" plist)
  6.             (list "popup3" plist)
  7.             (list "popup4" slist)
  8.         )
  9.         (start_list  (car  lst))
  10.         (foreach itm (cadr lst) (add_list itm))
  11.         (end_list)
  12.     )
  13. )
But it's actually likely to be more efficient to simply do this:
  2.     (dclst "popup1" alist)
  3.     (dclst "popup2" plist)
  4.     (dclst "popup3" plist)
  5.     (dclst "popup4" slist)
  6. )
  7. (defun dclst ( key lst )
  8.     (start_list key)
  9.     (foreach itm lst (add_list itm))
  10.     (end_list)
  11. )
« Last Edit: May 29, 2021, 05:13:59 PM by Lee Mac »
civil.eng
« Reply #12 on: May 30, 2021, 04:40:10 PM »
Woooov, you are fabulous. thank you lee mac
