Author Topic: AutoCAD 2020 freeze While working  (Read 3068 times)
HasanCAD
« on: December 12, 2020, 10:51:39 AM »
Hi All
I am using AutoCAD 2020 at work.
- While working autocad freeze for seconds or more then comes back to work.
- When copy or move objects autocad make reactor, How to stop REACTOR in AutoCAD while copy or move objects? (Attached snapshot)
ribarm
  • Marko Ribar, architect
Re: AutoCAD 2020 freeze While working
« Reply #1 on: December 12, 2020, 01:30:55 PM »
Use LISP for copy and move... Aquire points by (getpoint) and finally supply points as tokens to COPY or MOVE commands... For ex. (command "_.COPY" ss "" "_non" p1 "_non" p2)
M.R. on Youtube
HasanCAD
« Reply #2 on: December 13, 2020, 07:06:34 AM »
Thanks  Good solution
tombu
  • ByLayer=>Not0
« Reply #3 on: December 29, 2020, 03:21:19 PM »
If I was having those issues with Copy and Move I'd add a toggle for DRAGMODE (System Variable)
http://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-0690A755-3B81-44E7-9AB2-5DFED263642F
Tom Beauford P.S.M.
HasanCAD
« Reply #4 on: December 30, 2020, 01:13:16 AM »
YES
This is what I am looking for
