Author Topic: big text select problem  (Read 1465 times)
dussla
« on: September 20, 2020, 04:20:19 AM »
hi firends
sorry i have  a problem ~ :oops:
this is  big text  extract code
pls  can you open attached file
with code if i select  object ,   result  is "aaaa"
pls what problem ?
(defun c:tl ()
(setq square (car (entsel "\n select object :: ")))
  (setq obj (vlax-ename->vla-object square))
  (setq lst (cons obj lst))
        (setq pts (gc:MBoundingBox lst))
      (setq ss (ssget "w" (car pts) (cadr pts)  '((0 . "TEXT,MTEXT"))) )
(setq i 0 )
(repeat (sslength ss)
(setq en (ssname ss i)
text-list (append text-list (list en))
i (1+ i)))
(setq th-list nil)
(mapcar '(lambda (x) (setq th-list (append th-list (list (cdr (assoc 40 (entget x))))))) text-list)
(setq MaxText (nth (car (vl-sort-i th-list '>)) text-list))
(setq    tvaluse (cdr(assoc 1 (entget maxtext))))
(defun gc:MBoundingBox (ObjectList / CoordList)
  (foreach o ObjectList
    (vla-getBoundingBox o 'minPt 'maxPt)
    (setq CoordList (cons (vlax-safearray->list minPt)
                          (cons (vlax-safearray->list maxPt) CoordList)
  (list (apply 'mapcar (cons 'min CoordList))
        (apply 'mapcar (cons 'max CoordList))
« Last Edit: September 20, 2020, 04:24:55 AM by dussla »
roy_043
  • BricsCAD 18
Re: big text select problem
« Reply #1 on: September 20, 2020, 05:00:28 AM »
You need to localize the variable in the c:tl function.
https://www.theswamp.org/index.php?topic=55680.0
dussla
« Reply #2 on: September 20, 2020, 01:37:39 PM »
really thank you , thank you ~
dussla
« Reply #3 on: September 20, 2020, 02:37:10 PM »
sorry    i made code some
but still error
ps  : this code work process code
        pls understand me ~~
problem :
1. slow
2. error: bad argument type: lselsetp nil ( if i select   many  boundray rectangle   )
pls can you modify  some  ~
that is my limit
modified code
 (defun   C:ask( / k objset obj oyr ss  i text-list th-list entall )
 (setvar "osmode" 33)
(setq k 0)
(setq objset (ssget (list '(0 . "*polyline") (cons 410 (getvar 'ctab)))))
    (repeat (sslength objset)
            (setq obj (ssname objset k))
             (setq oyr (vlax-ename->vla-object obj))
             (setvar "osmode" 0)
            (vla-getboundingbox oyr 'minpt 'maxpt)
            (setq minpt (vlax-safearray->list minpt)
            maxpt (vlax-safearray->list maxpt)
            (setq ss (ssget "_w" minpt maxpt (list (cons 0 "text"))))
               (setq i 0 )
                  i (1+ i))
            (setq th-list nil)
            (setq    pltn (cdr(assoc 1 (entget  MaxText))))
               (setq  allsee (ssget "_X" '((60 . 0)(0 . "~VIEWPORT"))))
               (setq  sd  (ssget  "x"  (list '(0 . "hatch") (cons 410 (getvar "ctab")))))
               (setq  tsd  (ssget  "x"  (list '(0 . "*TEXT") (cons 410 (getvar "ctab")))))
               (off sd)
               (off tsd)
               (setq entall (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
               (vlax-map-collection entall '(lambda(x) (vla-put-visible x -1)))
               (setq  sd  (ssget  "x"  (list '(0 . "hatch")   )))
               (seiso  allsee sd )
               (setq  sd  (ssget  "x"  (list '(0 . "*TEXT")   )))
               (seiso  allsee sd )
(setq   k ( 1+ k )   )
(defun seiso (seAll seon /   idx)
  (setq idx 0)
  (repeat (sslength seAll)
    (vlax-put-property (vlax-ename->vla-object (ssname seAll idx)) 'Visible :vlax-false)
    (setq idx (1+ idx))
    );end repeat
  (setq idx 0)
  (repeat (sslength seOn)
    (vlax-put-property (vlax-ename->vla-object (ssname seOn idx)) 'Visible :vlax-true)
    (setq idx (1+ idx))
    );end repeat
(defun OFF(OL / OBJNUM SSOBJ OBJECT OBJLIST)
   (setq OBJNUM 0)
      (repeat (sslength OL)
            (setq SSOBJ (entget (ssname OL OBJNUM))
                 OBJNUM (+ OBJNUM 1)
                 OBJECT (append SSOBJ (list (cons 60 1)))
         (if (= (cdr (assoc 0 SSOBJ)) "VIEWPORT")
            (princ "\nViewports cannot be turned off.")
         (entmod OBJECT)
roy_043
  • BricsCAD 18
« Reply #4 on: September 21, 2020, 11:57:29 AM »
pls can you
I am sure it would be very convenient for you to have a person at the ready to check and improve your code whenever the need arises. But I am not that person.
