Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Create Electric Single Line Diagram importing Excel file
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Create Electric Single Line Diagram importing Excel file (Read 2794 times)
jtm2020hyo
Newt
on:
May 09, 2020, 02:22:13 AM »
Is there a way to create a single line Electrical Diagram from an imported Excel file with LISP or similar?
Logged
https://www.patreon.com/jtm2020hyo
DEVITG
Bull Frog
Re: Create Electric Single Line Diagram importing Excel file
Reply #1 on:
May 09, 2020, 09:03:23 AM »
yes it is.
give us both xls, dwg , and what do you want to do
Logged
Location @ Córdoba Argentina Using ACAD 2019 at Window 10
jtm2020hyo
Newt
Reply #2 on:
May 09, 2020, 11:06:33 AM »
no problems, wait for me some hours.
Logged
jtm2020hyo
Newt
Reply #3 on:
May 09, 2020, 11:07:30 PM »
This took me the entire day, but finally, I did. In theory, should be possible to draw any Single line diagram. if anyone helps me with the lisp I might create a SLD template for everyone. if possible explain a bit of your lisp.
PD: attached files
related links:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/create-electric-single-line-diagram-importing-excel-file/m-p/9503679#M399622
https://forums.autodesk.com/t5/revit-architecture-forum/create-electric-single-line-diagram-importing-excel-file/td-p/9503318
https://www.theswamp.org/index.php?topic=56014.0
https://forums.autodesk.com/t5/revit-mep-forum/create-electric-single-line-diagram-importing-excel-file/td-p/9504525
Logged
jtoverka
Newt
Reply #4 on:
May 11, 2020, 01:53:13 PM »
Below is a link to an AutoCAD Electrical Automation technique
https://www.autodesk.com/autodesk-university/class/I-Feel-Need-Need-Speed-AutoCAD-Electrical-Automation-2016
If you are starting out in LISP and automation and programming is not your main strength, then that is where you should start. It's a hack of the PLCIO utility. It can be used for everything else, including one lines.
Logged
jtm2020hyo
Newt
Reply #5 on:
May 11, 2020, 06:14:05 PM »
I am very grateful. thanks for your help.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
