Author Topic: What to do with a list like this?  (Read 2074 times)
myloveflyer
« on: April 01, 2020, 02:38:12 AM »
lst1 ‘(("N" "123.123,234.234,345.345") ("W" "456.456,567.567,678.678") ("E" "789.789,890.890,900.900"))
lst2 ’ ((“1” "X1" "789.789,890.890,900.900" "123.123,234.234,345.345"  "1" "5") (”2“ "Y1" "789.789,890.890,900.900" "456.456,567.567,678.678"  "1" "3"))
lst_x ‘((“1” "X1" "N" "E" "1" "5") (“2” "Y1" "W" "E" "1" "3"))
« Last Edit: April 01, 2020, 04:09:12 AM by myloveflyer »
Never give up !
Dlanor
Re: What to do with a list like this?
« Reply #1 on: April 01, 2020, 04:02:34 AM »
  1. ;lst1(("N" "123") ("W" "234") ("E" "345"))
  2. ;lst2 (("X1" "123" "345" “1” “5”) ("Y1" "234" "345" “1” “3”))
  3. ;========》
  4. ;lst_x(("X1" "N" "E" “1” “5”) ("Y1" "W" "E" “1” “3”))
  5.
  6. (defun test (lst1 lst2 / lst)
  7. (setq lst1 (mapcar '(lambda (x) (reverse x)) lst1))
  8. (foreach x lst2
  9.   (setq lst (cons (mapcar '(lambda (y) (if (assoc y lst1) (cadr (assoc y lst1)) y)) x) lst))
  10. )
  11. (reverse lst)
  12. )
  13.
  14. ;(setq lst_x (test '(("N" "123") ("W" "234") ("E" "345")) '(("X1" "123" "345" “1” “5”) ("Y1" "234" "345" “1” “3”))))
  15.
myloveflyer
« Reply #2 on: April 01, 2020, 04:11:34 AM »
  3. ;========》
  5.
  8. (foreach x lst2
  10. )
  11. (reverse lst)
  12. )
  13.
  15.
Hi,Dlanor
What if lst2 has one more element!
Never give up !
Dlanor
« Reply #3 on: April 01, 2020, 04:58:53 AM »
It works for me, although it returns ((“1” "X1" "E" "N" "1" "5") (”2“ "Y1" "E" "W" "1" "3")), because that was the order in lst2. Its just a substitution function.
myloveflyer
« Reply #4 on: April 01, 2020, 05:32:52 AM »
Hi,Dlanor!
Wrong return ((“1” "X1" "E" "N" "1" "5") (”2“ "Y1" "E" "W" "1" "3"))
Correct return ((“1” "X1" "N" "E" "1" "5") (”2“ "Y1" "W" "E" "1" "3"))
How to sort "N" "W" "E"?
Never give up !
Dlanor
« Reply #5 on: April 01, 2020, 08:59:33 AM »
Then what are the criteria for the sort? Are the number strings coordinates? I don't understand how you arrive at the two lists, and why there are two lists.
myloveflyer
« Reply #6 on: April 01, 2020, 09:42:30 AM »
Dlanor,YES!
Number strings is coordinates!
Never give up !
Dlanor
« Reply #7 on: April 01, 2020, 11:11:20 AM »
Then it would be better to store the number in the list as a coordinate. It is far easier to sort using numbers/coordinates than a text representation which has to be converted back to a number.
myloveflyer
« Reply #8 on: April 01, 2020, 11:57:56 AM »
Hi!Dlanor
Listen to your suggestion, I used to sort the coordinates and then get the new list, everything went well!
Thank you very much!
Never give up !
