Author Topic: How to delete a text file using lisp in Autocad?  (Read 2342 times)
Vikram
« on: March 12, 2020, 01:57:43 AM »
I have made this lisp to delete a file but its not working. Path is correct I checked executing same path. But I also tried using the command "DEL" in cmd to delete the file from that folder and it gives error "System cannot find path specified" I tried using cmd in admin mode but no success.
Command: "DEl C:\\Log_Files\\ABC.mtn"
(the text file is in .mtn extension)
Interesting thing is it deletes the file which are on Desktop
(defun c:DSTDEL ( /  fnam )
(setq fnam (strcat "C:\\Log_Files\\"(vl-filename-base (getvar "dwgname")) ".mtn"))
(setq cmd (strcat "DEL " fnam))
(command "SHELL" cmd)
« Last Edit: March 12, 2020, 02:04:48 AM by Vikram »
kpblc
Re: How to delete a text file using lisp in Autocad?
« Reply #1 on: March 12, 2020, 02:20:35 AM »
Use vl-file-delete function:
  1. (if (findfile file)
  2.   (vl-file-delete file)
  3.   )
Sorry for my English.
Vikram
« Reply #2 on: March 12, 2020, 02:34:18 AM »
Thanks for suggestion!
Though I found out the problem.
My path was something like this C:\CAD Files\Log_Files\ABC.txt
cmd was not able to find files where there is space between folder names for example here its CAD Files. I renamed that folder to CAD-Files and my lisp worked fine
jvillarreal
« Reply #3 on: March 12, 2020, 07:22:18 AM »
Double quoting the path is the solution many others have applied when using shell commands.
baitang36
« Reply #4 on: March 29, 2020, 09:34:03 AM »
(defun C:YJKP() (ALERT "Please leave as soon as you are under 18" )
(setq A1 "http://v.qq.com/x/cover/2iqrhqekbtgwp1s.html")
 (command "browser" A1 )
 (PRINC)
BIGAL
  • 40 + years of using Autocad
« Reply #5 on: April 01, 2020, 09:33:13 PM »
(vl-file-delete filename)
ahsattarian
« Reply #6 on: November 21, 2020, 03:12:31 PM »
try this   :
(acet-file-remove filename)
