Author Topic: Dynamic Breakline  (Read 5051 times)
Fella 77
  • Mosquito
Dynamic Breakline
« on: March 03, 2020, 10:00:50 AM »
Hi
I created this dynamic breakline but I'm having an issue with the break jog. I set this up so you can stretch each end of the breakline, and you can stretch the center jog up and down along the breakline, and also rotate the breakline. It works pretty good but I am having an issue with the jog only going so far up along the breakline y axis. You can pull it downward along Y as much as you want..even going past the end of the breakline...but when you try and stretch it upwards along y, at a certain point it disappears. I have tried a bunch of things and I can't seem to get it to work. Also I want the grip for the rotate to move with the grip for the jog but it seems to get misaligned. The solid fill in the jog is my background mask..solid fill set to color 254 so it will mask anything below it in the draw order. Any help with this would be appreciated..I'm sure it's something dumb I am overlooking. Thanks in advance
