Author Topic: Variable value within a list  (Read 2032 times)
DanB
« on: January 30, 2020, 11:56:50 AM »
I'm struggling with applying a defined value and sending to a list. The list does not reflect my desired results. I've never been good with bound and local variables. Suggestions?
Undesired result =(("Val1" VALUE1) ("Val2" VALUE2))
Desired result =(("Val1" 10.22) ("Val2" 99.99))
example
(defun uservalues (/ saved_values)
 (setq saved_values
  '(("Val1" value1)
    ("Val2" value2)
   ) ; ends list of values
 ); ends setq
) ; end defun
(defun c:TEST (/)
 (setq value1 "10.22")
 (setq value2 "99.99")
 (uservalues)
Re: Variable value within a list
« Reply #1 on: January 30, 2020, 12:21:53 PM »
A little vague: are you talking about custom variables and values (like an association list) or are you talking about AutoCAD settings/variables?
This snip comes to you from the member ElpanovEvgeniy and has to do with storing and setting AutoCAD settings/variables. However, you can use a similar method for your own variables. ...or use association lists. So many options.
  1.      ERROR-LST-
  2.      '("AUTOSNAP" "OSMODE" "APERTURE" "HPSPACE" "HPASSOC"
  3.        "MIRRTEXT" "AUPREC" "LUPREC" "DIMZIN" "CECOLOR" "CLAYER"
  4.        "CMDECHO" "FILEDIA" "OSMODE")
  5.      ERROR-LST- (mapcar (function (lambda (a) (list 'setvar a (getvar a)))) ERROR-LST-)
  6.      )
  7. (mapcar 'eval ERROR-LST-)
DanB
« Reply #2 on: January 30, 2020, 12:33:02 PM »
I'm trying to write a routine involving a dialog box. I have a function that sets default values for the edit boxes. I then want to store any user changes so when the dialog is opened repeatedly the user sees their latest values, not the defaults. Below was an overly simplified example of how I attempted to pass the user values to a list.
« Reply #3 on: January 30, 2020, 12:58:31 PM »
Oh? Well, then you want to save the variable/values to a file. Without specifics, below is an example of how I saved the layers, for the drawing, to a file and how I read them back into a list which I could use in my program (simple example but a little more applicable).
  1. (defun save-layer-list-to-file ( / x f fp )
  2.   ;; retrieve all layers from dwg dict and save
  3.   ;; to a file.  file saved where drawing is located
  4.       (setq f (strcat (getvar 'DWGPREFIX) (getvar 'DWGNAME) ".la")
  5.             fp (open f "A"))
  6.       (while (setq x (tblnext "LAYER" (not x)))
  7.              (cond
  8.                ((not (>= (cdr (assoc 70 x)) 16))
  9.                 (prin1 x fp)
  10.                 (princ "\n" fp)) )
  11.              )
  12.       (close fp)
  13.       (princ) )
  14.
  15. (defun get-list-from-file ( name / fp lst read-file-into-list )
  16.   ;; general file reader
  17.   ;; given a file name this procedure will read the contents
  18.   ;; into a list
  19.          (defun read-file-into-list ( str file )
  20.            (if str
  21.              (cons
  22.                (if (not (wcmatch str "*;*")) str "")
  23.                ;; get string from file; if it is a comment, return an empty string.
  24.                (read-file-into-list (read-line file) file))))
  25.   (setq fp (open name "R"))
  26.   (setq lst (read-file-into-list (read-line fp) fp))
  27.   (close fp)
  28.  lst
  29. )
  30.
« Reply #4 on: January 30, 2020, 01:08:52 PM »
The key is the use of the apostrophe/single-quote: this operator instructs the AutoLISP interpreter to interpret what follows as literal data, not requiring evaluation. Consequently, the symbols value1 & value2 are not evaluated to yield the values they hold, but rather remain as symbols. I delve into this in far more detail with several examples in my tutorial on The Apostrophe and the Quote Function.
For your particular example, the solution would be to construct the list using the list function, which evaluates its supplied arguments:
  1. (defun uservalues ( / saved_values )
  2.     (setq saved_values
  3.         (list
  4.             (list "Val1" value1)
  5.             (list "Val2" value2)
  6.         )
  7.     )
  8. )
  9.
  10. (defun c:TEST ( / )
  11.    (setq value1 "10.22")
  12.    (setq value2 "99.99")
  13.    (uservalues)
  14. )
Note that it may be better practice to supply the values as arguments to the uservalues function, and then assign the variable saved_values to the return of this function, as in your current code, the variables value1 and value2 are global. For example:
  1. (defun uservalues ( v1 v2 )
  2.     (list
  3.         (list "Val1" v1)
  4.         (list "Val2" v2)
  5.     )
  6. )
  7.
  8. (defun c:TEST ( / value1 value2 )
  9.    (setq value1 "10.22")
  10.    (setq value2 "99.99")
  11.    (setq saved_values (uservalues value1 value2))
  12. )
This is obviously a very contrived example.
DanB
« Reply #5 on: January 30, 2020, 01:15:43 PM »
Thank you both for your assistance. I think this can get me back on track.
BIGAL
  • 40 + years of using Autocad
« Reply #6 on: January 31, 2020, 09:22:09 PM »
In a dcl you can set default value so either as mentioned save in a txt file or for this session make it a global variable but be careful about its name.
(if (not AH:but)(setq AHbut 1)) then call dcl.
There is some defaults in the dwg you can use Useri1-5 integers, Userr1-5 reals, Users1-5 strings, these get saved in the dwg, but can be used by any one.
Another is (setenv "myval1" 12)  (Getenv "myval1")
« Last Edit: January 31, 2020, 09:26:45 PM by BIGAL »
