Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
How to align text in this lisp
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How to align text in this lisp (Read 3425 times)
HasanCAD
Swamp Rat
on:
December 14, 2019, 05:40:15 AM »
Hi all,
I upgrade LEE lisp to mach my needs
and I want to make change so I want some one to help
Code - Auto/Visual Lisp:
[Select]
;; Layer Legend - Lee Mac
;; Generates a set of lines at a user-specified point and of a given length
;; with associated layer name text sorted alphabetically for every layer in a drawing.
;; https://www.cadtutor.net/forum/topic/64214-legends-lisp/
defun
c:LLD
c:LayerLegend
defun
c:LayerLegend
df i l ln p1 pt sp dsc ent nm lst desc objs
vl-load-com
defun
*error*
msg
LM:endundo
LM:acdoc
if
not
wcmatch
strcase
msg t
"*break,*cancel*,*exit*"
princ
strcat
\n
Error: "
msg
princ
defun
layercount:
assoc
key lst
itm
if
setq
itm
assoc
key lst
subst
cons
key
1+
cdr
itm
itm lst
cons
cons
key
1
lst
if
and
setq
pt
getpoint
\n
Specify Point for Legend: "
setq
pt
trans
pt
1
0
setq
ln
100
getvar
'TEXTSIZE
setq
sp
2.5
getvar
'TEXTSIZE
setq
i
1
progn
vlax-for
blk
vla-get-blocks
vla-get-activedocument
vlax-get-acad-object
vlax-for
obj blk
setq
lst
layercount:
assoc
vla-get-layer
obj
lst
if
and
"AcDbBlockReference"
vla-get-objectname
obj
:vlax-true
vla-get-hasattributes
obj
foreach
att
vlax-invoke
obj 'getattributes
setq
lst
layercount:
assoc
vla-get-layer
att
lst
while
setq
df
tblnext
"LAYER"
null
df
if
16
logand
16
cdr
assoc
70
df
setq
l
cons
cdr
assoc
2
df
l
setq
l
acad_strlsort l
foreach
n l
setq
ent
vlax
ename
vla-object
tblobjname
"LAYER"
n
setq
objs
assoc
n lst
setq
objs
cdr
objs
setq
dsc
vlax-get-property
ent 'Description
setq
nm
vlax-get-property
ent 'name
entmakex
list
cons
0
"LINE"
cons
8
n
cons
6
"ByLayer"
cons
62
256
cons
10
setq
p1
polar
pt
1.5
pi
setq
i
1+
i
sp
cons
11
polar
p1
0
. ln
cons
370
1
entmakex
list
cons
0
"TEXT"
cons
1
strcat
n
" - Objs: "
itoa
objs
" - Desc: "
dsc
;* (the string itself)
cons
6
"BYLAYER"
; Linetype name
cons
7
getvar
'TEXTSTYLE
;* Text style name, defaults to STANDARD, not current
cons
8
n
; layer
cons
10
p1
;* First alignment point (in OCS)
cons
11
p1
;* Second alignment point (in OCS)
cons
39
0.0
; Thickness (optional; default = 0)
cons
40
getvar
'TEXTSIZE
;* Text height
cons
41
1.0
; Relative X scale factor, Width Factor, defaults to 1.0
cons
62
256
; color
cons
71
0
; Text generation flags
cons
72
0
; Horizontal text justification type
cons
73
1
; Vertical text justification type
cons
210
list
0.0
0.0
1.0
cons
370
1
princ
Logged
Sorry for my English.
Donate to Theswamp
www.sergiwa.com
ribarm
Gator
Marko Ribar, architect
WWW
Re: How to align text in this lisp
Reply #1 on:
December 14, 2019, 06:42:11 AM »
You could try to make ACAD_TABLE entity instead... Text inside cells would be aligned as your wish...
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
BIGAL
Swamp Rat
40 + years of using Autocad
Reply #2 on:
December 15, 2019, 12:14:40 AM »
If you use mtext a tab is supported, you can add tabs in a string using (chr 9)
(cons 1 (strcat n " - Objs:" (chr 9) (itoa objs) (chr 9) " - Desc: " (chr 9) dsc)) ; not tested
Logged
Dlanor
Bull Frog
Reply #3 on:
December 15, 2019, 06:41:39 AM »
You could change the font to a monospaced eg Lucida Console which would make controlling the length of each sub string easier.
Logged
Dlanor
http://www.theswamp.org/donate.html
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
