Author Topic: 3D sheet piling type AZ  (Read 9458 times)
lamarn
« on: December 15, 2018, 05:22:08 AM »
Sheet piling AZ Arbed, mostly used in my country. For 3D use the connectors are simplified.
Is there a way to give the height of the pile a parameter inside a array? Thanks!
https://drive.google.com/file/d/13vgTwT8ZXfztwOm8qrUCxBt3NABsQKRP/view?usp=sharing
documentation
https://sheetpiling.arcelormittal.com/products-services/production-range/az-sections/
ChrisCarlson
Re: 3D sheet piling type AZ
« Reply #1 on: December 20, 2018, 11:30:44 AM »
Not that I'm aware of, AutoDesk never really updated the block editor to work with 3D objects.
« Reply #2 on: December 20, 2018, 12:08:29 PM »
documentation
There is a way to add a z stretch to a dynamic block,  one has to play around with the UCS....
Crank
« Reply #3 on: December 20, 2018, 12:22:07 PM »
documentation
The problem is that the BEDIT command only works in 2D....
« Reply #4 on: December 20, 2018, 12:29:23 PM »
documentation
Yes, I know....but there was an instance where myself and a student, quite accidentally made a block with a z stretch element....
by mucking around with the UCS ....maybe I can do one later today...and post
ChrisCarlson
« Reply #5 on: December 20, 2018, 05:24:57 PM »
documentation
I'm curious now, I'm not sure how this industry operates but couldn't you just set the first 3d solid to the desired length and array that entity?
** UCS command not allowed in block editor. **
lamarn
« Reply #6 on: December 21, 2018, 03:54:55 AM »
documentation
There are some tricks to fool it but overall any z operations is limited. I will expect BricsCAD to that this further not any Autocad development during this century.
The reason why rounds should be avoided is the speed of the 3D graphics and the ability to get from DWG into IFC, Revit or any other CAD.
