Author Topic: Dialog Box Image Display  (Read 5792 times)
GDF
« on: November 06, 2018, 02:42:37 PM »
When going from model space to paper space the door image is displayed differently.
The door image color slide is yellow.
I want it to be displayed as dark blue in paper space (image 2) as it is in model space (image 1).
code below:
(setq shpimx (dimx_tile "shpimg")
        shpimy (dimy_tile "shpimg"))
  (start_image "shpimg")(slide_image
    -1
    1
    shpimx
    shpimy
    (strcat ARCH#SUPF "DRAW/ARCH_DRAW(" shimg ")"))
(fill_image 0 0 shpimx shpimy -15)
:image {key="shpimg"; color=-15; width=7.25; height=7.25;}
roy_043
  • BricsCAD 18
Re: Dialog Box Image Display
« Reply #1 on: November 07, 2018, 03:50:48 AM »
I have a hunch that this may be related to background colors. Are you using different background colors in MS and PS?
GDF
« Reply #2 on: November 07, 2018, 08:02:32 AM »
That was it...thanks.
In AutoCAD thsi was not a problem, only in BricsCAD
GDF
« Reply #3 on: November 07, 2018, 08:08:38 AM »
I changed the background color in paper space from 176 to 250, and that fixed the problem! I don't like the white background default color.
Thanks again Roy
roy_043
  • BricsCAD 18
« Reply #4 on: November 07, 2018, 03:01:47 PM »
Maybe the linework in your slide is dark blue? Because a yellow slide will appear as yellow if BKGCOLORPS is 176 or 250. The strange thing is that a color inversion based on the BKGCOLORPS does not occur for the color white. I have sent in a Support Request.
« Last Edit: November 07, 2018, 04:12:56 PM by roy_043 »
