Author Topic: Recall last input  (Read 2281 times)
milanp
Recall last input
« on: November 05, 2018, 02:03:51 PM »
Can somebody help me with this code. The default value is 1000 and everything works properly, but I would like to be offered the last entered value. Do you have any suggestions for modification? Thanks  :roll:
(defun C:skarpe (/ Gornja Donja Pitanje Razmera Razmera_totaal count p1 p2 boja)
 (command "layer" "make" "Skarpe" "color" "8" "Skarpe" "")
  (defun IS-ON-PL? (ENAME PKT /)
    (vl-catch-all-apply
      'vlax-curve-getdistatpoint
      (list
        ENAME
        PKT
        ) ;_ end of list
      ) ;_ end of vlax-curve-getDistAtPoint
    PKT
    ) ;_ end defun
(initget "1000 500 2500")
(setq Pitanje (cond ((getreal (strcat "\n Odaberi Razmeru 1:[1000/500/2500] <"(itoa (cond (Pitanje)((setq Pitanje 1000))))">: ")))(Pitanje)))
(if (= Pitanje 1000)
    (setq Razmera 1))
(if (= Pitanje 500)
    (setq Razmera 0.5))
(if (= Pitanje 2500)
(setq Razmera 2.5))
  (if (and (setq Gornja (car (entsel "\nSelektuj gornju povrsinu: ")))
           (setq Donja (car (entsel "\nSelektuj donju povrsinu: ")))
           (setq boja 256))
      (setq Razmera_totaal 0)
      (setq count 0)
      (setq p1 (vlax-curve-getStartPoint
                 (vlax-ename->vla-object Gornja)
                 ) ;_ end of vlax-curve-getStartPoint
            ) ;_ end of setq
      (while p1
        (if (equal (/ count 2.0) (fix (/ count 2.0)) 0.001)
          (setq p2
                 (vlax-curve-getClosestPointTo
                   (vlax-ename->vla-object Donja)
                   p1
                   ) ;_ end of vlax-curve-getClosestPointTo
                ) ;_ end of setq
          (setq
            p2 (MAPCAR '(LAMBDA (x) (/ x 2))
                       (MAPCAR '+
                               p1
                                 p1
                               ) ;_ end of MAPCAR
                       ) ;_ end of MAPCAR
            ) ;_ end of setq
          ) ;_ end of if
        (entmake
          (list '(0 . "LINE")
                (cons 10 p1)
                (cons 11 p2)
                ;'(62 . 1) ; standaard boja
                (cons 62 boja) ; boja dia dialog instellen
          ) ;_ end of list
        ) ;_ end of entmake
          (setq p1 (IS-ON-PL?
                     (vlax-curve-getpointatdist
                       (setq Razmera_totaal (+ Razmera_totaal Razmera))
                       ) ;_ end of vlax-curve-getpointatdist
                     ) ;_ end of IS-ON-PL?
                ) ;_ end of setq
           p1
           ) ;_ end of if
        (setq count (1+ count))
        ) ;_ end of while
      ) ;_ end of progn
    ) ;_ end of if
  ) ;_ end of defun
Re: Recall last input
« Reply #1 on: November 05, 2018, 03:35:48 PM »
Give this a try:
  1. (defun c:skarpe (/ gornja donja pitanje razmera razmera_totaal count p1 p2 boja)
  2.   (command "layer" "make" "Skarpe" "color" "8" "Skarpe" "")
  3.   (defun is-on-pl? (ename pkt /)
  4.     (vl-catch-all-apply
  5.       (list ename pkt) ;_ end of list
  6.     ) ;_ end of vlax-curve-getDistAtPoint
  7.     pkt
  8.   ) ;_ end defun
  9.   ;; Get or set default
  10.   (setq pitanje (cond ((getenv "skarpe"))
  11.                       ((setenv "skarpe" "1000"))
  12.                 )
  13.   )
  14.   (initget "1000 500 2500")
  15.   (setq pitanje (cond ((getkword (strcat "\n Odaberi Razmeru 1:[1000/500/2500] <" pitanje ">: ")))
  16.                       (pitanje)
  17.                 )
  18.   )
  19.   (setq razmera (/ (atof pitanje) 1000.))
  20.   (if (and (setq gornja (car (entsel "\nSelektuj gornju povrsinu: ")))
  21.            (setq donja (car (entsel "\nSelektuj donju povrsinu: ")))
  22.            (setq boja 256)
  23.       )
  24.     (progn
  25. ;; Write default
  26.       (setenv "skarpe" pitanje)
  27.            (setq razmera_totaal 0)
  28.            (setq count 0)
  29.            (setq p1 (vlax-curve-getstartpoint (vlax-ename->vla-object gornja)) ;_ end of vlax-curve-getStartPoint
  30.            ) ;_ end of setq
  31.            (while p1
  32.              (if (equal (/ count 2.0) (fix (/ count 2.0)) 0.001)
  33.                (setq p2 (vlax-curve-getclosestpointto (vlax-ename->vla-object donja) p1) ;_ end of vlax-curve-getClosestPointTo
  34.                ) ;_ end of setq
  35.                (setq
  36.                  p2 (mapcar '(lambda (x) (/ x 2))
  37.                             (mapcar '+
  38.                                     p1
  39.                                     (vlax-curve-getclosestpointto (vlax-ename->vla-object donja) p1) ;_ end of vlax-curve-getClosestPointTo
  40.                             ) ;_ end of MAPCAR
  41.                     ) ;_ end of MAPCAR
  42.                ) ;_ end of setq
  43.              ) ;_ end of if
  44.              (entmake (list '(0 . "LINE")
  45.                             (cons 10 p1)
  46.                             (cons 11 p2) ;'(62 . 1) ; standaard boja
  47.                             (cons 62 boja) ; boja dia dialog instellen
  48.                       ) ;_ end of list
  49.              ) ;_ end of entmake
  50.              (if (setq p1 (is-on-pl? (vlax-ename->vla-object gornja)
  51.                                      (vlax-curve-getpointatdist
  52.                                        (vlax-ename->vla-object gornja)
  53.                                        (setq razmera_totaal (+ razmera_totaal razmera))
  54.                                      ) ;_ end of vlax-curve-getpointatdist
  55.                           ) ;_ end of IS-ON-PL?
  56.                  ) ;_ end of setq
  57.                p1
  58.              ) ;_ end of if
  59.              (setq count (1+ count))
  60.            ) ;_ end of while
  61.     ) ;_ end of progn
  62.   ) ;_ end of if
  63. ) ;_ end of defun
ribarm
  • Marko Ribar, architect
« Reply #2 on: November 05, 2018, 03:40:06 PM »
Ovo treba ovako - po mom misljenju... Ali ova sub funkcija i nije potrebna - vidi poslednju liniju ukupne rutine (setq p1 (getpointatdist ... ))
;;(IS-ON-PL? ENAME PKT) => PKT - point is on curve or nil - point isn't on curve
  (defun IS-ON-PL? (ENAME PKT)
    (if (vlax-curve-getdistatpoint ENAME PKT)
      PKT
Ovo je uredu... Ali Pitanje varijabla treba da bude globalna, znaci izbaci je iz prve linije (defun C:skarpe (/ Gornja Donja Pitanje Razmera Razmera_total count p1 p2 boja)
  (setq Pitanje
      ( (getint
            (itoa
                (Pitanje)
                ( (setq Pitanje 1000) )
      (Pitanje)
Ovo treba ovako - po mom misljenju - treba check-irati da li je pored pick-ovanja entitet kriva - curve...
           (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getstartpoint (list Gornja))))
           (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getstartpoint (list Donja))))
           (setq boja 256))
Dovoljno je :
                 Gornja
                 ;;; (vlax-ename->vla-object Gornja) - nepotrebna koverzija ename->vla-object - vlax-curve-xxx funkcije rade brze i efikasnije sa ename argumentom
      ) ;_ end of setq
Znaci otprilike ovako bi izgledala kompletna rutina po mom misljenju koliko toliko kvalitetnija...
(defun c:skarpe ( / Gornja Donja Razmera Razmera_total count p1 p2 boja )
  (vl-cmdf "_.LAYER" "_M" "Skarpe" "_C" "8" "Skarpe" "")
  (setq Pitanje
      ( (getint
            (itoa
                (Pitanje)
      (Pitanje)
    ( (= Pitanje 1000)
      (setq Razmera 1)
    ( (= Pitanje 500)
      (setq Razmera 0.5)
    ( (= Pitanje 2500)
      (setq Razmera 2.5)
           (setq boja 256)
      (setq Razmera_total 0)
      (setq count 0)
      (setq p1 (vlax-curve-getStartPoint Gornja))
      (while p1
        (if (= (rem count 2) 0)
          (setq p2 (vlax-curve-getClosestPointTo Donja p1))
          (setq p2 (mapcar '(lambda ( x ) (/ x 2)) (mapcar '+ p1 (vlax-curve-getClosestPointTo Donja p1))))
        (entmake
          (list
               '(0 . "LINE")
                (cons 10 p1)
                (cons 11 p2)
                ;'(62 . 1) ; standard boja
                (cons 62 boja) ; boja 256 - ByLayer
        (setq p1 (vlax-curve-getpointatdist Gornja (setq Razmera_total (+ Razmera_total Razmera))))
HTH., M.R.
« Last Edit: November 06, 2018, 01:15:56 AM by ribarm »
M.R. on Youtube
milanp
« Reply #3 on: November 05, 2018, 04:08:34 PM »
I tried the lisp that ronjonp attached and everything works perfectly! Thanks a lot!
Marko hvala na detaljnom objasnjenju. Probao sam da ubacim tvoje resenje, ali nesto ne funkcionise kako treba. Radilo je sve ok, ali kad sam manuelno uneo vrednost (500) funkcija je u narednoj iteraciji prestala sa radom i vise nije htela da se pokrene (error: bad argument type: fixnump: 500.0).  Hvala jos jednom na pomoci. Pozdav!
« Reply #4 on: November 05, 2018, 04:49:32 PM »
If you simply remove 'Pitanje' from the list of declared local variables, your original code would have remembered the last entered value within the current drawing session.
ribarm
« Reply #5 on: November 05, 2018, 11:22:06 PM »
Pa zar ti to ne ukazuje da treba da koristis (getint) umesto (getreal), jer kasnije imas funkciju (itoa) - integer to ascii... Evo ispravio sam moju reviziju. Nadam se da je sada u redu... Inace kao sto Lee rece, pod uslovom da je sve ispravno bilo napisano, samo bi trebalo da se izbaci varijabla "Pitanje" iz lokalizacije...
M.R. on Youtube
milanp
« Reply #6 on: November 06, 2018, 05:22:17 PM »
Radi sve super. Hvala na ispravci
