Author Topic: Who Grades Pads / Lots / Walls?  (Read 2493 times)
estanima
« on: October 25, 2018, 09:46:24 PM »
Will people please share if you design grading for individual lots, set the elevations of the lot and/or house, and if you show walls / retaining walls on your plans. If you do, would you please note your location? I'm trying to see how many places this is a requirement like it is in my location.
Thanks!
DinØsaur
  • Certified Bovine Scat Distributor...I lay it on THICK
  • But I don't WANT a Day Job
Re: Who Grades Pads / Lots / Walls?
« Reply #1 on: October 26, 2018, 10:07:54 AM »
I used to do individual lot grading in Kansas City area ... particularly in developments with a complex topography.  There were also a few developments in quite flat areas that required some very precise grading.
Stephen R. Sherrill,
The DinØsaur
Civil 3D Specialist Emeritus
YAY ME !!!  I made it out alive !
« Reply #2 on: October 26, 2018, 11:52:26 AM »
I have in some places, and not in others.
I almost ask why one wouldn't? even if only as part of getting solid earthwork volume calculations, and sections if required.
AZ/NV
DinØsaur
« Reply #3 on: October 26, 2018, 01:36:11 PM »
There are some places where there is really no point ... again in the Kansas City area - some of the later development properties that had been passed over and with good cause.  One could almost count on finding massive rock formation after digging about half way to the target depth in a few areas resulting in plan modifications, sometimes on the fly during construction, if not outright redesign almost from scratch at times.  Once our client had to blast a number of trenches for the sewer system and service laterals even though there had been test holes drilled showing no problems.
The DinØsaur
