Author Topic: "Software disenchantment"  (Read 2392 times)
« on: September 25, 2018, 10:28:33 AM »
Only in software, it’s fine if a program runs at 1% or even 0.01% of the possible performance. Everybody just seems to be ok with it. People are often even proud about how much inefficient it is, as in “why should we worry, computers are fast enough”:
http://tonsky.me/blog/disenchantment/
Re: "Software disenchantment"
« Reply #1 on: September 25, 2018, 05:17:11 PM »
I wholeheartedly agree, I think the main problem stems from frameworks, no one writes 'algorithms' or routines anymore. Instead of building a routine with a hand built or standard library stack or dictionary they will troll the web looking for a package or framework that says it fits the bill.
Sure, you save yourself a few hundred lines of code but you injected 1000's more that you will never use and is possibly full of bugs! Not to mention the time to learn the framework and doc's, there's added maintenance of dependencies and updates/upgrades.
- John Carmack
- J.R.R. Tolkien
« Reply #2 on: September 25, 2018, 05:42:46 PM »
^^ I couldn't agree more...
This comes to mind:
https://media.giphy.com/media/8fjedJmOkkcTu/giphy.gif
« Reply #3 on: September 26, 2018, 08:12:39 AM »
Yep, agree. I got a kick out of the text editor rant.
I'm reminded of a slew of Theo de Raadt's quotes but I suppose this one would be a good summary.
Quote from: Theo de Raadt
Our solutions provide something that is 100% right, all the time. That is the idea. The cobbled together gunk never does [...] It's unfortunate the application-level people are all caught up in cobble, cobble, cobble and just never learn how to evolve.
https://en.wikiquote.org/wiki/Theo_de_Raadt
rkmcswain
« Reply #4 on: September 27, 2018, 09:18:06 AM »
Quote from: Lee Mac
This comes to mind:
That GIF is missing some frames at the end. You know, the part where the plug explodes and the whole thing burns.....
dgorsman
« Reply #5 on: September 27, 2018, 10:12:11 AM »
Hmmm... dissenting opinion here.  Had to stop reading after a quick browse.  Too much expectation of everything being perfect (or at least, perfect according to the poster), and some selective analysis.  Yes, "frameworks" might be considered lazy, and give a lot more than is normally used.  However, something purpose built from the ground up will more than likely need updating or maintenance; for complicated ones that leads to abandonware.  If every programmer takes the time to make their own "framework" they'll not only have much less time to work on the *actual* program, but there will be huge variances between program operation (right-click vs. left-click, for example).  There *is* a valid reason why frameworks like DirectX came to be.
That's not an argument for programmers being lazy though.  Hack'n'slash/copy-paste code writing should be avoided.  Those writing code should understand what they are trying to achieve, rather than getting others to do the legwork for them then proclaiming how awesome they are.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
