Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Identifing the visibility state a nested entity is associated with
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Identifing the visibility state a nested entity is associated with (Read 2433 times)
cadpoobah
Newt
WWW
on:
June 25, 2018, 02:47:56 PM »
All,
I'd like to generate a report of the entities nested within a block and know if each entity is associated with a visibility state. Can anyone tell me how to determine that info?
Thanks!
Chris
Logged
Chris Lindner
Onebutton CAD Solutions
www.onebuttoncad.com
#dayjob
www.unpavedart.com
#sidehustle
kpblc
Bull Frog
Re: Identifing the visibility state a nested entity is associated with
Reply #1 on:
June 25, 2018, 03:29:53 PM »
I thinck you have to check block reference (not by EffectiveName, but just Name) and going through all subentities check - are they visible or not.
Logged
Sorry for my English.
cadpoobah
Newt
WWW
Reply #2 on:
June 25, 2018, 03:47:53 PM »
Thanks, @kpblc.
You are correct; this would be for references. Similar to AutoCAD's LIST command, the user would be prompted to select a block reference. The report would be specific to the selected block.
Logged
Chris Lindner
#dayjob
www.unpavedart.com
#sidehustle
Seagull
London, England
WWW
Reply #3 on:
June 25, 2018, 05:50:44 PM »
The following function should return a list of entities visible for each visibility state for a given dynamic block:
Code - Auto/Visual Lisp:
[Select]
;; Visibility State Entities - Lee Mac
;; Returns an association list of visibility states and the entities visible for each state
;; blk - [str] Dynamic block name
defun
LM:vsentities
blk
ent enx rtn ste tmp vis
if
and
setq
ent
tblobjname
"block"
blk
setq
ent
cdr
assoc
330
entget
ent
setq
enx
member
102
"{ACAD_XDICTIONARY"
entget
ent
setq
ent
cdr
assoc
360
enx
setq
vis
vl-some
lambda
x
if
and
360
car
x
"BLOCKVISIBILITYPARAMETER"
cdr
assoc
0
entget
cdr
x
cdr
x
dictsearch
ent
"ACAD_ENHANCEDBLOCK"
foreach
itm
entget
vis
cond
303
car
itm
if
and
ste tmp
setq
rtn
cons
cons
ste
reverse
tmp
rtn
setq
ste
cdr
itm
tmp
nil
332
car
itm
setq
tmp
cons
cdr
itm
tmp
reverse
if
and
ste tmp
cons
cons
ste
reverse
tmp
rtn
rtn
For example:
[Select]
_$
LM:vsentities
"MyDynamicBlock"
"State 0"
Entity name: 7ffff7104d0
Entity name: 7ffff7104e0
"State 1"
Entity name: 7ffff7104f0
"State 2"
Entity name: 7ffff710500
"State 3"
Entity name: 7ffff7106b0
Logged
Lee Mac Programming
Twitter
Exchange App Store
cadpoobah
Newt
WWW
Reply #4 on:
June 26, 2018, 10:07:15 AM »
Thanks, Lee. That's perfect. I can tweak from there.
You continue to amaze, man. Your code is always 'spot on' and super clean.
Logged
Chris Lindner
#dayjob
www.unpavedart.com
#sidehustle
roy_043
Water Moccasin
BricsCAD 18
Reply #5 on:
June 26, 2018, 10:44:05 AM »
Isn't Lee's code for block definitions instead of references? Or am I missing something?
Logged
cadpoobah
Newt
WWW
Reply #6 on:
June 26, 2018, 02:12:44 PM »
You're right, @roy_043. For now, I'm using it as a general block definition ("what's inside this block") reporting tool. I'll eventually need a reference version as well.
Logged
Chris Lindner
#dayjob
www.unpavedart.com
#sidehustle
Seagull
London, England
WWW
Reply #7 on:
June 26, 2018, 05:02:18 PM »
Thanks cadpoobah, glad it helps.
Thank you also for your compliments for my code, I appreciate it.
The 'block reference' version is actually a lot easier, since you can simply query the contents of the anonymous block definition generated based on the current dynamic parameter values of the block and return the visible entities in the definition:
[Select]
defun
blockrefentities
ent
enx rtn
if
setq
ent
tblobjname
"block"
cdr
assoc
2
entget
ent
while
setq
ent
entnext
ent
if
1
cdr
assoc
60
entget
ent
setq
rtn
cons
ent rtn
reverse
rtn
The active visibility state can be ascertained using
this function
Logged
Lee Mac Programming
Twitter
Exchange App Store
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
