Author Topic: REPEAT problem  (Read 1924 times)
Jeremy Dunn
REPEAT problem
« on: May 17, 2018, 03:13:17 PM »
Here is an interesting question that I have yet to solve. I want to write REPEAT in such a way that it will take its arguments as a list. For instance
(defun MYREPEAT ( lst )
  (apply 'repeat lst)
Nope
  (apply 'repeat (apply 'progn lst))
Nope
I've tried all kinds of approaches but haven't created anything that will do more than one cycle. Any gurus out there to enlighten?
roy_043
  • BricsCAD 18
Re: REPEAT problem
« Reply #1 on: May 17, 2018, 04:25:57 PM »
Can't think of a good reason for this. But anyway:
  1. ; (myrepeat '(10 (if j (setq j (1+ j)) (setq j 1))))
  2. (defun myrepeat (lst)
  3.   (repeat (car lst) (eval (cadr lst)))
  4. )
ChrisCarlson
Re: REPEAT problem
« Reply #2 on: May 17, 2018, 04:52:23 PM »
What would your list look like that it would be able to limit the repeat function?
Grrr1337
Re: REPEAT problem
« Reply #3 on: May 17, 2018, 05:28:14 PM »
One way:
(defun MyRepeat ( L )
  (foreach x L
    (eval (cons 'repeat x))
_$ (MyRepeat
    (2 (print "A"))
    (1 (print "B"))
    (3 (print "C"))
"A"
"A"
"B"
"C"
"C"
"C" "C"
(apply ''((a b c)(a b c))
vevo.bg
Jeremy Dunn
Re: REPEAT problem
« Reply #4 on: May 18, 2018, 10:28:51 AM »
Grrrr, your way works but I had to modify it to
  (foreach x (list L)
I just wanted a single list of arguments to process, not several. It is a little mysterious to me as to why this works and why I have to put a list within a list. Ahh the subtleties of LISP.
Re: REPEAT problem
« Reply #5 on: May 18, 2018, 12:24:15 PM »
Why not reduce it to -
  1. (defun _repeat ( l ) (eval (cons 'repeat l)))
  1. _$ (progn (_repeat '(3 (print "A"))) (princ))
  2.
  3. "A"
  4. "A"
  5. "A"
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: REPEAT problem
« Reply #6 on: May 18, 2018, 02:25:09 PM »
  (apply 'repeat lst)
Nope
Nope
Jeremy,
You did not provide an essential part of your question.
What will be the contents of your list that you propose passing to the new function. ?
Please provide an example.
Called Kerry in my other life
I live at UTC + 13.00
Jeremy Dunn
Re: REPEAT problem
« Reply #7 on: May 18, 2018, 03:22:21 PM »
Kdub, the contents of the list are simply the lines of code that you would normally put in a REPEAT statement except that they are all in a list. For example,
(repeat 5
   (setq cnt (+ cnt 2))
would be
(MyRepeat (list 5 (setq cnt (+ cnt 2))))
Lee, I tried yours and it worked fine so long as I quoted the list but if I used (list instead it failed, why?
Re: REPEAT problem
« Reply #8 on: May 18, 2018, 06:38:05 PM »
The list function evaluates the arguments it is supplied before returning a list - you may wish to refer to my tutorial here.
