Author Topic: How to think like a programmer — lessons in problem solving  (Read 2600 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Called Kerry in my other life
I live at UTC + 13.00
Re: How to think like a programmer — lessons in problem solving
« Reply #1 on: April 20, 2018, 09:08:31 PM »
:thumbs up: :)
- John Carmack
- J.R.R. Tolkien
« Reply #2 on: April 21, 2018, 12:17:24 PM »
Good read.
« Reply #3 on: April 21, 2018, 12:54:00 PM »
Do not try to solve one big problem. You will cry.
Gold.
GDF
« Reply #4 on: April 21, 2018, 01:10:26 PM »
LUCK
Grrr1337
« Reply #5 on: April 21, 2018, 01:38:30 PM »
“Given input X, what are the steps necessary to return output Y?”
Don't we all follow that concept?
BTW the Understand/Plan/Divide paragraphs reminded me of MP's (well structured)coding style.
(apply ''((a b c)(a b c))
vevo.bg
kdub_nz
  • SuperMod
« Reply #6 on: April 21, 2018, 04:18:56 PM »
Dividing the task into manageable portions is a well established process ..
"How Do You Eat An Elephant?: One Bite at a Time"
https://www.amazon.com/How-Do-You-Eat-Elephant/dp/1595262040
« Reply #7 on: April 21, 2018, 06:14:08 PM »
No! As an example, if following that mindset you'd end up with several bullet points. Each of those bullet points "should" be a seperate procedure (a small procedure for each task). You hardly/rarely see this "proper" structure; you often find procedures structured in a rambling fashion (e.g. "SolveThisIssueAndDrawLinesWhileMakingAViewport").
That's because ha has more years of experience then the swamp has members. *wink* And, he was probably around when the computer monitor pixel density was 1.
« Reply #8 on: April 21, 2018, 08:45:57 PM »
The 'think first' part of the article reminds me of what Rich Hickey (creator of Clojure) calls 'hammock driven development' :)
- John Carmack
- J.R.R. Tolkien
« Reply #9 on: April 21, 2018, 09:55:53 PM »
My "style" is one born of necessity, experience and the product of much review early on of code by Ethan Winer, Pierre Lemire and Tony Tanzillo, the latter being comparable to what Dr. Jordan Peterson is to psychiatry circles today: outspoken, extraordinarily deep and organized thinker and overall brilliant practitioner.
« Reply #10 on: April 21, 2018, 10:03:15 PM »
Love it, I've always dubbed that my "look out the window time" ...
« Last Edit: April 21, 2018, 10:41:04 PM by MP »
« Reply #11 on: April 22, 2018, 05:08:14 PM »
"Now easy as pie!"
:-D
- John Carmack
- J.R.R. Tolkien
