Author Topic: Improvement of Lee Mac "ListBoxFunctionsV1-1.lsp" function  (Read 6992 times)
fabcad
« on: November 27, 2017, 02:56:51 PM »
Hello,
I would like to use the "ListBoxFunctionsV1-1.lsp" function, created by genius Lee Mac, I would like to recover at the end of the function two lists :
The first : full list sorted.
The second : list with only the choice of the user.
Thank you in advance,
In the example of the screenshot:
Full list sorted : ("Item 8" "Item 9" "Item 0" "Item 1" "Item 2" "Item 3" "Item 4" "Item 5" "Item 6" "Item 7")
List with only the choice of the user : ("Item 8" "Item 9")
Re: Improvement of Lee Mac "ListBoxFunctionsV1-1.lsp" function
« Reply #1 on: November 27, 2017, 03:39:58 PM »
If you're using Lee's example program here, just add something like this to the end.
  1. (list lst (mapcar '(lambda (x) (nth x lst)) idx))
