Author Topic: Success with raster to vector  (Read 2511 times)
mbrandt5
« on: October 26, 2017, 03:04:21 PM »
Has anyone had success with raster to vector conversion...
Obviously if you get a pdf you can import it into cad with layers...
But say you get a jpeg or a png file.  The program inkscape is a free program that does not necessecarily trace bitmaps the greatest for insert into cad via dxf or other formats for that matter.
Has anyone out there had success with such conversions, to the extent that walls and windows actually convert properly?
Hence with pictures of drawings a floor plan could grow out of a it.
MickD
Re: Success with raster to vector
« Reply #1 on: October 26, 2017, 04:12:22 PM »
I do some drawings for a friend who does patio awnings and additions, he never gets a CAD file to start with so most times I open the (usually scanned) image in an image editor, Inverse the colours (so you get a black background with white lines) and insert it into the drawing. I then set the transparency level so I can just see it and then trace over the lines I need, scale to the correct units and delete the inserted image.
It's not super accurate but it's enough for additions and such.
hth
- John Carmack
- J.R.R. Tolkien
mbrandt5
« Reply #2 on: October 26, 2017, 04:51:47 PM »
Yeah, there is always the insert and trace method.  Yeah I am interested in turning that 30 minutes to hours into seconds.
Any input I am sure will be dually appreciated.
ChrisCarlson
« Reply #3 on: October 27, 2017, 09:53:36 AM »
I don't think it will be readily possible anytime soon. The data stored in a raster file is far less than that of a vector file.
mbrandt5
« Reply #4 on: October 27, 2017, 10:52:50 AM »
time is relative   :smitten: :smitten:
Peter2
« Reply #5 on: November 06, 2017, 09:54:43 AM »
Do you ask for a special software or for common experience? If you want to test a software take a look at www.softelec.com
Peter
BricsCAD V23
mbrandt5
« Reply #6 on: November 20, 2017, 06:25:20 PM »
Any chance that is a free software?
Peter2
« Reply #7 on: November 21, 2017, 04:02:54 PM »
Sorry, I only know commercial software ....
Peter
BricsCAD V23
