Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Selection set
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Selection set (Read 1169 times)
Biscuits
Swamp Rat
Selection set
on:
July 12, 2017, 09:01:06 AM »
How would I go about creating a selection set that would include a circle (if it exists) and anything inside it and return the diameter as a variable to be used later in a routine? This has me stumped.
Thanks for any ideas.
Logged
Needs a day job
Re: Selection set
Reply #1 on:
July 12, 2017, 09:10:52 AM »
First thing that comes to mind is pick the circle, trace it with points then use ssget "WP".
Logged
PKENEWELL
Bull Frog
Re: Selection set
Reply #2 on:
July 26, 2017, 03:19:08 PM »
Here's and oldie from my CAD library. Change the line with (setq ss (ssget "CP" ptlst)) to "WP" to select all inside only. You can also increase or decrease the accuracy by changing the value of the "inc" variable.
Code - Auto/Visual Lisp:
[Select]
;; ----- (pjk-ssget-cir [Entity Name]) ----------------
;; This function selects all the objects within or crossing a
;; circle with the [Entity Name] given. Returns the resulting
;; selection set.
defun
pjk
ssget
cir
enam
cnt cen elst ful inc pt ptlst rad ss
if
enam
progn
setq
elst
entget
enam
ptlst
nil
cen
trans
cdr
assoc
10
elst
enam
0
rad
cdr
assoc
40
elst
inc
1.0
ful
360.0
inc
cnt
0.0
;; Created a Point list for 360 points on curcumference of
;; the circle to use with "Crossing Polygon" selection.
while
cnt ful
setq
pt
polar
cen
pjk
dtr cnt
rad
ptlst
cons
pt ptlst
cnt
inc cnt
reverse
ptlst
;; Delete the circle.
entdel
enam
;; Select by Crossing polygon.
setq
ss
ssget
"CP"
ptlst
;; Undelete the Circle.
entdel
enam
ss
nil
;; End Function (pjk-ssget-cir)
Logged
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Selection set
