Author Topic: Help with a lisp :Point perpendicular to line  (Read 2925 times)
pedroantonio
« on: May 15, 2017, 01:59:44 AM »
Hi .I am using this lisp to draw perpendicular line from a point to line.
I want to do a change .don't draw me a line but insert a point onthe section of the tow lines like the photo
  1. (defun c:perp (/ e 2p ad d p pp) ;perpendicular to line
  2. ;hanhphuc 29.10.15
  3. (COMMAND "_layer" "_m" "section" "_c" "10" "" "")
  4. (setvar 'pdmode 35)
  5.   (if (and (setq e (car (entsel "\nPick a LINE.. ")))
  6.            (= (cdr (assoc 0 (setq e (entget e)))) "LINE")
  7.            )
  8.     (while (setq p (getpoint "\nSpecify a POINT.. "))
  9.       (setq 2p (mapcar ''((x) (trans (cdr (assoc x e))0 1) ) '(10 11))
  10.             ad (mapcar '(lambda (f) (apply f (mapcar ''((x) (list (car x) (cadr x))) 2p)))
  11.                        '(angle distance))
  12.             d  (vxv (mapcar '- p (car 2p)) (mapcar ''((f) (f (car ad))) (list cos sin)))
  13.             pp (polar (car 2p) (car ad) d)
  14.             )
  15.       (entmakex
  16.         (vl-list* '(0 . "LINE")
  17.                   (mapcar '(lambda (a b) (cons a (trans b 1 0)))
  18.                           '(10 11)
  19.                           (list p
  20.                                 (list (car pp)(cadr pp)(+ (* (/ (apply '- (mapcar 'last (reverse 2p))) (cadr ad)) d)
  21.                                           (caddr (car 2p)))
  22.                                        )
  23.                                 )
  24.                           )
  25.                   )
  26.         )
  27.       )
  28.     )
  29.   (princ)
  30.   )
  31.
  32. ;; Vector Dot Product  -  Lee Mac
  33. ;; Args: u,v - vectors in R^n
  34.
  35. (defun vxv ( u v )
  36.     (apply '+ (mapcar '* u v))
  37. )
  38.
  39.
BIGAL
  • 40 + years of using Autocad
Re: Help with a lisp :Point perpendicular to line
« Reply #1 on: May 15, 2017, 05:14:33 AM »
Much easier done with vla-getclosestpointto pick line pick point done.
(setq pt (getpoint))
(setq obj (vlax-ename->vla-object (car (entsel "\nPick line"))))
(setq pt2 (vlax-curve-getclosestpointto obj  pt))
pedroantonio
« Reply #2 on: May 15, 2017, 10:17:42 AM »
hi bigal. The  change ineed to do is this
a) select the line (or pt1 and pt2)
b) select pt3
c) draw a perpedicular point on the line pt1 -->pt2
with
(setvar 'pdmode 35)
Can you help me?
thanks
« Reply #3 on: May 15, 2017, 01:16:06 PM »
Try the following:
  1. (defun c:perpt ( / dis enx pt1 pt2 pt3 sel tmp )
  2.     (while
  3.         (not
  4.             (progn (setvar 'errno 0) (setq sel (entsel "\nSelect line or polyline segment: "))
  5.                 (cond
  6.                     (   (= 7 (getvar 'errno))
  7.                         (prompt "\nMissed, try again.")
  8.                     )
  9.                     (   (null sel))
  10.                     (   (= "LINE" (cdr (assoc 0 (setq enx (entget (car sel))))))
  11.                         (setq pt1 (trans (cdr (assoc 10 enx)) 0 1)
  12.                               pt2 (trans (cdr (assoc 11 enx)) 0 1)
  13.                               dis (distance pt1 pt2)
  14.                         )
  15.                     )
  16.                     (   (= "LWPOLYLINE" (cdr (assoc 0 enx)))
  17.                         (setq tmp (vlax-curve-getclosestpointto (car sel) (trans (cadr sel) 1 0))
  18.                               tmp (fix (+ 1e-8 (vlax-curve-getparamatpoint (car sel) tmp)))
  19.                               pt1 (trans (vlax-curve-getpointatparam (car sel)     tmp)  0 1)
  20.                               pt2 (trans (vlax-curve-getpointatparam (car sel) (1+ tmp)) 0 1)
  21.                               dis (distance pt1 pt2)
  22.                         )
  23.                     )
  24.                     (   (prompt "\nThe selected object is not a line or 2D polyline."))
  25.                 )
  26.             )
  27.         )
  28.     )
  29.     (if (and pt1 pt2 (setq pt3 (getpoint "\nSpecify 3rd point: ")))
  30.         (entmake
  31.             (list
  32.                '(000 . "POINT")
  33.                '(008 . "section")
  34.                 (cons 010
  35.                     (trans
  36.                         (polar pt1
  37.                             (angle pt1 pt2)
  38.                             (apply '+
  39.                                 (mapcar '*
  40.                                     (mapcar '- pt3 pt1)
  41.                                     (mapcar '(lambda ( a b ) (/ (- a b) dis)) pt2 pt1)
  42.                                 )
  43.                             )
  44.                         )
  45.                         1 0
  46.                     )
  47.                 )
  48.                 (cons 210 (trans '(0 0 1) 1 0 t))
  49.             )
  50.         )
  51.     )
  52.     (princ)
  53. )
pedroantonio
« Reply #4 on: May 15, 2017, 02:02:22 PM »
thank you  Lee Mac
