Author Topic: Select all objects on a color  (Read 6723 times)
danny
« on: May 23, 2005, 07:51:50 PM »
I've seen a routine like this on the Swamp before, just can't seem to find it.  Can anyone help?  Select all objects on a color and change layer.
Thanks,
« Reply #1 on: May 23, 2005, 08:17:42 PM »
danny
« Reply #2 on: May 23, 2005, 08:32:55 PM »
CAB,
That is a great routine, and I also like quick select.  But, I need to be able to run it in a script file.  Sorry, I should have been more specific.
danny
« Reply #3 on: May 24, 2005, 02:48:38 PM »
o.k I tried this, but got a bad ssget list.  What did I do wrong?  Just trying to get all object on color 8 and change them to layer xxfine.
(defun c:c2lay ()
  (setq sset
(ssget
  "x"
  '((62.8))
  (if sset
    (repeat (sslength sset)
      (command "_.chprop" sset "" "layer" "xxfine" "")
Jürg Menzi
  • Oberegg, Switzerland
« Reply #4 on: May 24, 2005, 02:52:08 PM »
Quote from: danny
'((62.8))
must be:
'((62 . 8))note the spaces...
Cheers
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
whdjr
« Reply #5 on: May 24, 2005, 03:00:58 PM »
You also have to step thru each item in a selection set using nth.
Try this:
(defun c:c2lay (/ sset len)
  (setq sset (ssget "x" '((62 . 8))))
  (if sset
    (repeat (setq len (sslength sset))
      (setq len (1- len))
      (command "_.chprop" (nth len sset) "" "layer" "xxfine" "")
Jürg Menzi
« Reply #6 on: May 24, 2005, 03:06:15 PM »
ahem...
(if sset
Should be enough
Cheers
whdjr
« Reply #7 on: May 24, 2005, 03:08:12 PM »
Yeah that would work as well.  I didn't think of that I just fixed his repeat problem.
danny
« Reply #8 on: May 24, 2005, 03:20:42 PM »
So essentially, this is all I need?
(defun c:c2lay ()
  (setq   sset
    (ssget
      "x"
      '((62 . 8))
  (if sset
« Reply #9 on: May 24, 2005, 03:24:33 PM »
As long as it's not 'bylayer' :)
whdjr
« Reply #10 on: May 24, 2005, 03:25:38 PM »
Yup!
However it is nice to localize your variables:
(defun c:c2lay (/ sset)
danny
« Reply #11 on: May 24, 2005, 03:29:30 PM »
oh darn... Just noticed that too.  How can I select colors even if its 'bylayer'?
« Reply #12 on: May 24, 2005, 05:52:50 PM »
You need to make a list of layers that are of the color you want to filter.....Someone, coulda even been me, posted something that does this sometime in the past year or so. Lemme check......
« Reply #13 on: May 24, 2005, 06:05:07 PM »
OK, here's one I made up that also catches all entities within blocks...... uses ActiveX methods & proporties and no selection set.
After thinking about this, if you want to keep trying your own solution I'm not posting the code here. If you want to see and/or use it, I'm posting it to the Lilly Pond
danny
« Reply #14 on: May 24, 2005, 07:26:55 PM »
Jeff,
I was thinking about trying ActiveX, if plain lisp didn't work.  I wish I had enough time to learn this method.  Eventually I'll get there...Thanks to the Swamp for everthing, I've become twice as efficient.  Well...I do spend a lot of time browsing around in here. :)
So, if I had this list
WHITE = _XBOLD
YELLOW = _BOLD
CYAN = _MED
RED = _FINE
MAGENTA = _XFINE
GREY = _XXFINE
how or where would I input this in your code?
