Author Topic: Min Bounding Box of INSERT  (Read 8102 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: Min Bounding Box of INSERT
« Reply #15 on: April 06, 2017, 12:22:32 AM »
Refri,
Thanks for your comments.
Perhaps you could send a Personal Message to the supplier and give him your email address.
Generally we are wary of executable and compiled files being distributed here.
The Swamp is primarily a resource for peer support and as such we prefer code postings are source code ( or source snippets).
Unfortunately the potential dangers in VB6 EXE files or compiled lisp files is not discoverable by a virus scan.
Personally I find teaching/helping users code (and find solutions) for themselves  more rewarding for everyone  than turning the site into a dumping ground for anonymous unsecured programs.
Regards,
« Last Edit: April 06, 2017, 12:29:10 AM by kdub »
Called Kerry in my other life
I live at UTC + 13.00
mailmaverick
« Reply #16 on: April 06, 2017, 12:42:39 AM »
Hi
Maratovich's solution seems OK but I need the LISP code, not VB6.
Also, I need bounding box of only the Text Part "JJ-1" and not the entire block.
Thanks.
« Reply #17 on: April 06, 2017, 09:13:34 AM »
Hi
You should revise your example picture in the first post "Third Image : The Bounding Box which I want"  .. the current one shows the desired result as the entire block bounding box.
ChrisCarlson
« Reply #18 on: April 06, 2017, 10:04:01 AM »
Hi
Thanks.
Couldn't that just be summed up to
and
  1. vlax-safeArray->list
maratovich
  • Mosquito
« Reply #19 on: April 06, 2017, 11:37:09 AM »
 :whistling:
mailmaverick
« Reply #20 on: April 06, 2017, 11:38:03 AM »
Master_Shake,
Since the text attribute is within a Block (which is not exploded), we cannot use vla-getBoundingBox function on it.
It gives following error :- "Automation Error. Null extents".
« Reply #21 on: April 06, 2017, 12:14:24 PM »
Master_Shake,
Not true. My guess is you're encountering an attribute with no textstring assigned. You merely need to trap the attempt to get said bounding box and branch accordingly.
(defun _GetBoundingBox ( object / a b )
    (vl-catch-all-apply 'vlax-invoke-method (list object 'GetBoundingBox 'a 'b))
    (if a (mapcar 'vlax-safearray->list (list a b)))
(if (setq bb (_GetBoundingBox obj))
    (then)
    (else)
« Reply #22 on: April 06, 2017, 12:36:00 PM »
Since you're only looking for the bounding box of the attribute reference, here is a Vanilla solution to consider:
  1. (defun c:test ( / ent enx idx sel )
  2.     (if (setq sel (ssget '((0 . "INSERT") (66 . 1))))
  3.         (repeat (setq idx (sslength sel))
  4.             (setq ent (entnext (ssname sel (setq idx (1- idx))))
  5.                   enx (entget ent)
  6.             )
  7.             (while (= "ATTRIB" (cdr (assoc 0 enx)))
  8.                 (entmake
  9.                     (append
  10.                        '(
  11.                             (000 . "LWPOLYLINE")
  12.                             (100 . "AcDbEntity")
  13.                             (100 . "AcDbPolyline")
  14.                             (090 . 4)
  15.                             (070 . 1)
  16.                         )
  17.                         (list (cons 38 (cadddr (assoc 10 enx))))
  18.                         (mapcar '(lambda ( p ) (cons 10 p)) (LM:textbox ent))
  19.                         (list (assoc 210 enx))
  20.                     )
  21.                 )
  22.                 (setq ent (entnext ent)
  23.                       enx (entget  ent)
  24.                 )
  25.             )
  26.         )
  27.     )
  28.     (princ)
  29. )
  30.
  31. ;; Text Box  -  Lee Mac
  32. ;; A wrapper for the textbox function to return the bounding box of a Text or Attrib (in OCS)
  33.
  34. (defun LM:textbox ( ent / ins mat rot )
  35.     (setq ent (entget ent)
  36.           ins (cdr (assoc 10 ent))
  37.           rot (cdr (assoc 50 ent))
  38.           mat (list
  39.                   (list (cos rot) (sin (- rot)) 0.0)
  40.                   (list (sin rot) (cos rot)     0.0)
  41.                  '(0.0 0.0 1.0)
  42.               )
  43.     )
  44.     (mapcar '(lambda ( x ) (mapcar '+ (mxv mat x) ins)) (LM:points->boundingbox (textbox ent)))
  45. )
  46.
  47. ;; Points to Bounding Box  -  Lee Mac
  48. ;; Returns the rectangular extents of a supplied point list
  49.
  50. (defun LM:points->boundingbox ( lst )
  51.     (   (lambda ( l )
  52.             (mapcar '(lambda ( a ) (mapcar '(lambda ( b ) ((eval b) l)) a))
  53.                '(
  54.                     (caar   cadar)
  55.                     (caadr  cadar)
  56.                     (caadr cadadr)
  57.                     (caar  cadadr)
  58.                 )
  59.             )
  60.         )
  61.         (mapcar '(lambda ( f ) (apply 'mapcar (cons f lst))) '(min max))
  62.     )
  63. )
  64.
  65. ;; Matrix x Vector  -  Vladimir Nesterovsky
  66. ;; Args: m - nxn matrix, v - vector in R^n
  67.
  68. (defun mxv ( m v )
  69.     (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
  70. )
  71.
« Reply #23 on: April 06, 2017, 12:39:22 PM »
Very nice Lee  8)
« Reply #24 on: April 06, 2017, 12:41:38 PM »
Thanks Ron  :-)
mailmaverick
« Reply #25 on: April 06, 2017, 01:18:22 PM »
Once again Lee Mac to the rescue. Your code works perfect.
Thanks a lot Lee.
Grrr1337
« Reply #26 on: April 06, 2017, 02:36:25 PM »
I like your subfunctions Lee,
Although for LM:points->boundingbox wouldnt a more adequate function naming be LM:points->4ptboundingbox ?
(apply ''((a b c)(a b c))
vevo.bg
« Reply #27 on: April 06, 2017, 04:54:37 PM »
Thanks a lot Lee.
You're welcome mailmaverick, I'm glad it helps.
Thanks Grrr1337; the boundingbox is rectangular hence 4 points is implied.  :-)
