Author Topic: COND vs LISTS question  (Read 2096 times)
V-Man
« on: March 17, 2017, 10:48:54 AM »
Hi guys,
I am trying to find the best, easiest solution to my code. From the code below I am getting the drawing name and then from that I am also able to extract the floor number base on how we name our drawings. I am then writing a condition statement  for when the floor number matches then assign a variable base on the floor number.
(setq DV:FILE-NAME (strcase (getvar "DWGNAME")));Retrieve Drawing Name
(setq DV:FLOOR-NUMBER (substr DV:FILE-NAME 5 2));Retrieve Floor Number
         ((= DV:FLOOR-NUMBER 01) (progn (setq DV:DRAWING-TITLE "1ST FLOOR PLAN")))
         ((= DV:FLOOR-NUMBER 02) (progn (setq DV:DRAWING-TITLE "2ND FLOOR PLAN")))
         ((= DV:FLOOR-NUMBER 03) (progn (setq DV:DRAWING-TITLE "3RD FLOOR PLAN")))
         ((= DV:FLOOR-NUMBER 04) (progn (setq DV:DRAWING-TITLE "4TH FLOOR PLAN")))
         ((= DV:FLOOR-NUMBER 05) (progn (setq DV:DRAWING-TITLE "5TH FLOOR PLAN")))
         )end Cond
I have a list of floors "written out" below which is just a snippet of the entire list  but if I code it with Cond then it will be very long. How can I accomplish this so the code is more manageable? Is the answer LISTS? I'm just not sure.
01:FIRST FLOOR
02:SECOND FLOOR
03:THIRD FLOOR
04:FOURTH FLOOR
05:FIFTH FLOOR
Thanks for any assistance.
Grrr1337
Re: COND vs LISTS question
« Reply #1 on: March 17, 2017, 11:27:36 AM »
From what I know: cond for a bunch of evaluations, represents vl-some for unevaluated list (that consists functions to be evaluated).
So the alternative ways (using lists) are :
vl-some
  1. (setq DV:DRAWING-TITLE
  2.   (vl-some '(lambda (a b) (if (= a DV:FLOOR-NUMBER) b))
  3.     '(01 02 03 04 05)
  4.     '("1ST FLOOR PLAN" "2ND FLOOR PLAN" "3RD FLOOR PLAN" "4TH FLOOR PLAN" "5TH FLOOR PLAN")
  5.   ); vl-some
  6. ); setq
  7.
But if its possible avoid lambda evaluation, especially when you can use list accessors like assoc / nth :
assoc
  2.   (cadr
  3.     (assoc DV:FLOOR-NUMBER
  4.       '((01 "1ST FLOOR PLAN")
  5.         (02 "2ND FLOOR PLAN")
  6.         (03 "3RD FLOOR PLAN")
  7.         (04 "4TH FLOOR PLAN")
  8.         (05 "5TH FLOOR PLAN")
  9.       )
  10.     )
  11.   )
  12. ); setq
nth
  2.   (nth (1- DV:FLOOR-NUMBER)
  3.     '("1ST FLOOR PLAN" "2ND FLOOR PLAN" "3RD FLOOR PLAN" "4TH FLOOR PLAN" "5TH FLOOR PLAN")
  4.   )
  5. ); setq
(apply ''((a b c)(a b c))
vevo.bg
V-Man
« Reply #2 on: March 17, 2017, 11:47:11 AM »
  (cadr
); setq
I like this method. Thanks for the input. In my case the floor number is a string not an integer. So I had to place quotes around them.
  (cadr
      '(("01" "1ST FLOOR PLAN")
        ("02" "2ND FLOOR PLAN")
        ("03" "3RD FLOOR PLAN")
        ("04" "4TH FLOOR PLAN")
        ("05" "5TH FLOOR PLAN")
); setq
« Reply #3 on: March 17, 2017, 02:08:59 PM »
You could do something like this so you don't need to keep a list :) .
*Code removed because it didn't work.
« Last Edit: March 20, 2017, 08:54:20 AM by ronjonp »
« Reply #4 on: March 17, 2017, 02:40:23 PM »
Here's another:
  1. (defun floornumber ( str )
  2.     (   (lambda ( n ) (strcase (strcat (itoa n) (LM:ordinal n) " FLOOR PLAN"))) (atoi str))
  3. )
  4. (defun LM:ordinal ( n )
  5.     (cond
  6.         (   (< 10 (rem n 100) 14) "th")
  7.         (   (nth  (rem n 10) '(nil "st" "nd" "rd")))
  8.         (   "th"   )
  9.     )
  10. )
  1. _$ (floornumber "3")
  2. "3RD FLOOR PLAN"
  3. _$ (floornumber "13")
  4. "13TH FLOOR PLAN"
@Ron  :wink::
  1. _$ (_floornumber "13")
  2. "13RD FLOOR PLAN"
Grrr1337
« Reply #5 on: March 17, 2017, 04:24:24 PM »
Lee, I really like your LM:ordinal function, so I wrote this version for Bulgarian language:
(defun LM:ordinal_Bulgarian ( n / nl L s )
  (if (numberp n)
      (setq nl (read (last (setq L (mapcar 'chr (vl-string->list (setq s (vl-prin1-to-string n))))))))
      (strcat s
          ( (nth n '("лев" "ви" "ри")) )
          ( (vl-position n '(7 8)) "ми")
          ( (vl-position n '(3 4 5 6 9 10 11 12 13 14 15 16 17 18 19)) "ти")
          ( (zerop nl)
            (if (vl-every 'zerop (mapcar 'read (list (car (reverse L)) (cadr (reverse L))))) "ен" "ти")
          ( (nth nl '(nil "ви" "ри")) )
          ( (vl-position nl '(7 8)) "ми")
          (T "ти")
        ); cond
    ); progn
  ); if
); defun
vevo.bg
« Reply #6 on: March 17, 2017, 05:02:33 PM »
Here's another:
  3. )
  5.     (cond
  8.         (   "th"   )
  9.     )
  10. )
  2. "3RD FLOOR PLAN"
@Ron  ;) :
Doh ! 😁
V-Man
« Reply #7 on: March 17, 2017, 05:06:14 PM »
Thanks Lee Mac, Grrr1337 and RonjonP for the examples. For what it's worth I am providing my completed code. I know there must be a better and/or more efficient way to code this but this does work.
Any constructive criticism always welcome. You guys have a good weekend.
Thanks,
V-Man
« Reply #8 on: March 18, 2017, 12:34:05 AM »
        (   "th"   )
"3RD FLOOR PLAN"
"13TH FLOOR PLAN"
Hey LeeMac, I really think your approach will fit better to keep the code shorter but in my list of floors I also have uncommon floor names. For instance....
("B1" "BASEMENT 1 FLOOR PLAN")
    ("SB" "SUB-BASEMENT 1 FLOOR PLAN")
    ("M1" "MEZZANINE 1 FLOOR PLAN")
    ("R1" "ROOF 1 FLOOR PLAN")
    ("P1" "PENTHOUSE 1 FLOOR PLAN")
    ("GF" "GROUND FLOOR PLAN")
How can I accommodate these floors?
Thanks,
hanhphuc
« Reply #9 on: March 18, 2017, 02:10:43 AM »
This is just simplified cond + mapcar
(setq DV:FLOOR-NUMBER "M1")
(eval
  (cons 'cond
(mapcar '(lambda (n m)
   (list (eval (cons 'eq (list DV:FLOOR-NUMBER 'n)))
(cons 'setq
       (list 'DV:DRAWING-TITLE
     (strcat m
     " FLOOR PLAN"
'("B1" "SB" "M1" "R1" "P1" "GF")
'("BASEMENT 1 " "SUB-BASEMENT 1 " "MEZZANINE 1 " "ROOF 1 " "PENTHOUSE 1 " "GROUND ")
;"MEZZANINE 1  FLOOR PLAN"
but your data not typical or generic i prefer assoc list like Grrr
or dcl dialog
Lee's won shortest
( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" ) ; error: too many arguments
Grrr1337
« Reply #10 on: March 18, 2017, 06:39:46 AM »
Nice (eval (cons 'foo L)) technique, hanhphuc!
Some more tests, just for fun:
  1. _$ (setq n 3)
  2. 3
  3. _$ (vl-some '(lambda (x) (eval (cons 'if x)))
  4.   '(
  5.     ((= n 1) "1ST")
  6.     ((= n 2) "2ND")
  7.     ((= n 3) "3RD")
  8.     ((= n 4) "4TH")
  9.     ((= n 5) "5TH")
  10.   )
  11. )
  12. "3RD"
  13. _$ (eval
  14.   (cons 'cond
  15.     '(
  16.       ((= n 1) "1ST")
  17.       ((= n 2) "2ND")
  18.       ((= n 3) "3RD")
  19.       ((= n 4) "4TH")
  20.       ((= n 5) "5TH")
  21.     )
  22.   )
  23. )
  24. "3RD"
  25. _$
But I was always wondering why something simple like this won't work:
(apply 'cond AssocList) :
  1.   '(
  2.     ((= n 1) "1ST")
  3.     ((= n 2) "2ND")
  4.     ((= n 3) "3RD")
  5.     ((= n 4) "4TH")
  6.     ((= n 5) "5TH")
  7.   )
  8. )
(vl-some 'if AssocList) :
  1.   '(
  2.     ((= n 1) "1ST")
  3.     ((= n 2) "2ND")
  4.     ((= n 3) "3RD")
  5.     ((= n 4) "4TH")
  6.     ((= n 5) "5TH")
  7.   )
  8. )
:thinking:
vevo.bg
V-Man
« Reply #11 on: March 19, 2017, 10:20:24 AM »
hanhphuc
This seems to work. Appreciate it
(eval
  (cons   'cond
          (cons 'setq
                 (strcat    m
                    " FLOOR PLAN"
(setq DV:FLOOR-NUMBER "B1")
(eval
  (cons 'cond
(cons 'setq
     (strcat m
     " FLOOR PLAN"
'("B9" "B8" "B7" "B6" "B5" "B4" "B3" "B2" "B1" "S9" "S8" "S7" "S6" "S5" "S4" "S3" "S2" "S1" "SB" "M9" "M8" "M7" "M6" "M5" "M4" "M3" "M2" "M1"
  "R9" "R8" "R7" "R6" "R5" "R4" "R3" "R2" "R1" "P9" "P8" "P7" "P6" "P5" "P4" "P3" "P2" "P1" "G1" "GF" "00"
  "01" "02" "03" "04" "05" "06" "07" "08" "09" "10" "11" "12" "13" "14" "15" "16" "17" "18" "19" "20" "21" "22" "23" "24" "25" "26" "27" "28" "29" "30"
  "31" "32" "33" "34" "35")
'("BASEMENT 9" "BASEMENT 8" "BASEMENT 7" "BASEMENT 6" "BASEMENT 5" "BASEMENT 4" "BASEMENT 3" "BASEMENT 2" "BASEMENT 1" "SUB-BASEMENT 9" "SUB-BASEMENT 8" "SUB-BASEMENT 7"
  "SUB-BASEMENT 6" "SUB-BASEMENT 5" "SUB-BASEMENT 4" "SUB-BASEMENT 3" "SUB-BASEMENT 2" "SUB-BASEMENT 1" "SUB-BASEMENT" "MEZZANINE 9" "MEZZANINE 8" "MEZZANINE 7"
  "MEZZANINE 6" "MEZZANINE 5" "MEZZANINE 4" "MEZZANINE 3" "MEZZANINE 2" "MEZZANINE 1" "ROOF 9" "ROOF 8" "ROOF 7" "ROOF 6" "ROOF 5" "ROOF 4" "ROOF 3" "ROOF 2" "ROOF 1"
  "PENTHOUSE 9" "PENTHOUSE 8" "PENTHOUSE 7" "PENTHOUSE 6" "PENTHOUSE 5" "PENTHOUSE 4" "PENTHOUSE 3" "PENTHOUSE 2" "PENTHOUSE 1" "GROUND" "GROUND" "GROUND"
  "FIRST" "SECOND" "THIRD" "FOURTH" "FIFTH" "SIXTH" "SEVENTH" "EIGHTH" "NINTH" "TENTH" "ELEVENTH" "TWELFTH" "THIRTEENTH" "FOURTEENTH" "FIFTEENTH"
  "SIXTEENTH" "SEVENTEENTH" "EIGHTEENTH" "NINTEENTH" "TWENTIETH" "TWENTY-FIRST" "TWENTY-SECOND" "TWENTY-THIRD" "TWENTY-FOURTH" "TWENTY-FIFTH"
  "TWENTY-SIXTH" "TWENTY-SEVENTH" "TWENTY-EIGHTH" "TWENTY-NINTH" "THIRTIETH" "THIRTY-FIRST" "THIRTY-SECOND" "THIRTY-THIRD" "THIRTY-FOURTH" "THIRTY-FIFTH")
;"BASEMENT 1 FLOOR PLAN"
:yes:
« Reply #12 on: March 19, 2017, 11:45:22 AM »
At this point you might as well go back to using an association list, i.e.:
  2.     (strcat
  3.         (cdr
  4.             (assoc DV:FLOOR-NUMBER
  5.                '(
  6.                     ("B9" . "BASEMENT 9")
  7.                     ("B8" . "BASEMENT 8")
  8.                     ("B7" . "BASEMENT 7")
  9.                     ("B6" . "BASEMENT 6")
  10.                     ("B5" . "BASEMENT 5")
  11.                     ("B4" . "BASEMENT 4")
  12.                     ("B3" . "BASEMENT 3")
  13.                     ("B2" . "BASEMENT 2")
  14.                     ("B1" . "BASEMENT 1")
  15.                     ("S9" . "SUB-BASEMENT 9")
  16.                     ("S8" . "SUB-BASEMENT 8")
  17.                     ("S7" . "SUB-BASEMENT 7")
  18.                     ("S6" . "SUB-BASEMENT 6")
  19.                     ("S5" . "SUB-BASEMENT 5")
  20.                     ("S4" . "SUB-BASEMENT 4")
  21.                     ("S3" . "SUB-BASEMENT 3")
  22.                     ("S2" . "SUB-BASEMENT 2")
  23.                     ("S1" . "SUB-BASEMENT 1")
  24.                     ("SB" . "SUB-BASEMENT")
  25.                     ("M9" . "MEZZANINE 9")
  26.                     ("M8" . "MEZZANINE 8")
  27.                     ("M7" . "MEZZANINE 7")
  28.                     ("M6" . "MEZZANINE 6")
  29.                     ("M5" . "MEZZANINE 5")
  30.                     ("M4" . "MEZZANINE 4")
  31.                     ("M3" . "MEZZANINE 3")
  32.                     ("M2" . "MEZZANINE 2")
  33.                     ("M1" . "MEZZANINE 1")
  34.                     ("R9" . "ROOF 9")
  35.                     ("R8" . "ROOF 8")
  36.                     ("R7" . "ROOF 7")
  37.                     ("R6" . "ROOF 6")
  38.                     ("R5" . "ROOF 5")
  39.                     ("R4" . "ROOF 4")
  40.                     ("R3" . "ROOF 3")
  41.                     ("R2" . "ROOF 2")
  42.                     ("R1" . "ROOF 1")
  43.                     ("P9" . "PENTHOUSE 9")
  44.                     ("P8" . "PENTHOUSE 8")
  45.                     ("P7" . "PENTHOUSE 7")
  46.                     ("P6" . "PENTHOUSE 6")
  47.                     ("P5" . "PENTHOUSE 5")
  48.                     ("P4" . "PENTHOUSE 4")
  49.                     ("P3" . "PENTHOUSE 3")
  50.                     ("P2" . "PENTHOUSE 2")
  51.                     ("P1" . "PENTHOUSE 1")
  52.                     ("G1" . "GROUND")
  53.                     ("GF" . "GROUND")
  54.                     ("00" . "GROUND")
  55.                     ("01" . "FIRST")
  56.                     ("02" . "SECOND")
  57.                     ("03" . "THIRD")
  58.                     ("04" . "FOURTH")
  59.                     ("05" . "FIFTH")
  60.                     ("06" . "SIXTH")
  61.                     ("07" . "SEVENTH")
  62.                     ("08" . "EIGHTH")
  63.                     ("09" . "NINTH")
  64.                     ("10" . "TENTH")
  65.                     ("11" . "ELEVENTH")
  66.                     ("12" . "TWELFTH")
  67.                     ("13" . "THIRTEENTH")
  68.                     ("14" . "FOURTEENTH")
  69.                     ("15" . "FIFTEENTH")
  70.                     ("16" . "SIXTEENTH")
  71.                     ("17" . "SEVENTEENTH")
  72.                     ("18" . "EIGHTEENTH")
  73.                     ("19" . "NINTEENTH")
  74.                     ("20" . "TWENTIETH")
  75.                     ("21" . "TWENTY-FIRST")
  76.                     ("22" . "TWENTY-SECOND")
  77.                     ("23" . "TWENTY-THIRD")
  78.                     ("24" . "TWENTY-FOURTH")
  79.                     ("25" . "TWENTY-FIFTH")
  80.                     ("26" . "TWENTY-SIXTH")
  81.                     ("27" . "TWENTY-SEVENTH")
  82.                     ("28" . "TWENTY-EIGHTH")
  83.                     ("29" . "TWENTY-NINTH")
  84.                     ("30" . "THIRTIETH")
  85.                     ("31" . "THIRTY-FIRST")
  86.                     ("32" . "THIRTY-SECOND")
  87.                     ("33" . "THIRTY-THIRD")
  88.                     ("34" . "THIRTY-FOURTH")
  89.                     ("35" . "THIRTY-FIFTH")
  90.                 )
  91.             )
  92.         )
  93.         " FLOOR PLAN"
  94.     )
  95. )
V-Man
« Reply #13 on: March 19, 2017, 03:39:26 PM »
    (strcat
        (cdr
                    ("R9" . "ROOF 9")
                    ("R8" . "ROOF 8")
                    ("R7" . "ROOF 7")
                    ("R6" . "ROOF 6")
                    ("R5" . "ROOF 5")
                    ("R4" . "ROOF 4")
                    ("R3" . "ROOF 3")
                    ("R2" . "ROOF 2")
                    ("R1" . "ROOF 1")
                    ("G1" . "GROUND")
                    ("GF" . "GROUND")
                    ("00" . "GROUND")
                    ("01" . "FIRST")
                    ("02" . "SECOND")
                    ("03" . "THIRD")
                    ("04" . "FOURTH")
                    ("05" . "FIFTH")
                    ("06" . "SIXTH")
                    ("07" . "SEVENTH")
                    ("08" . "EIGHTH")
                    ("09" . "NINTH")
                    ("10" . "TENTH")
                    ("11" . "ELEVENTH")
                    ("12" . "TWELFTH")
        " FLOOR PLAN"
Thanks LeeMac.
