Author Topic: Civil 3D 2017 - MapWSpace SLOOOOOOOOOW  (Read 8088 times)
alanjt
  • Standby for witty remark...
« on: February 23, 2017, 10:18:30 AM »
Has anyone noticed when bringing in a SHP file with MAPWSPACE in c3d2017, if the SHP file has any significant amount of data, the file completely bogs down and you can't pan/zoom around?
Recently upgraded from 2014 and never had a problem.
I'm even loading the same SHP files in 2017 that were fine in previous c3d versions.
Dropbox
BlackBox
Re: Civil 3D 2017 - MapWSpace SLOOOOOOOOOW
« Reply #1 on: February 23, 2017, 12:41:56 PM »
I've not noticed that, although that may just be due to the fact that I generally MAPIMPORT Shapefiles, and only use MAPWSPACE for drawing queries of the imported Object Data.
What exactly are you 'bringing in' from the Shapefile(s) using MAPWSPACE?
The only thing I have noticed slowing a session to a crawl, is a pick of even a single imported Polyline that has too many vertices, with no real way to force a deselect (until the select is finished). GRIPOBJLIMIT only accounts for the number of entities selected, and not the max number of Grips to be displayed.
Cheers
« Reply #2 on: October 16, 2017, 09:36:35 AM »
is the data local, or on a network?
If on a network test with a local copy.
alanjt
« Reply #3 on: October 16, 2017, 09:50:07 AM »
The data is on a network. I'll give it a try.
Odd thing is, it's been fine on previous version loading from a network drive.
Dropbox
« Reply #4 on: October 16, 2017, 10:08:01 AM »
It happens here quite a bit, due to excessive use of DFS (our data is somewhere in an AMAZON Server Rack)
But our contract IT people are infallible  :uglystupid2:  according to management.
« Reply #5 on: October 16, 2017, 10:49:31 AM »
you might even check your MAPOPTIONS for this setting....and verify amount of space available there.
alanjt
« Reply #6 on: October 16, 2017, 11:48:18 AM »
Don't see anything different from yours.
This also isn't isolated to myself; everyone has experienced the lag since we upgraded to 2017.
Dropbox
