Author Topic: TotalArea, TotalPerim Lisp Error  (Read 1901 times)
asami486
« on: January 31, 2017, 08:15:05 PM »
I got these LISP file at http://gile.pagesperso-orange.fr/LISP.html
(Always Thanks Mr. GileCAD)
But these Lisp don't work for me.
When I command, I got the following messages.
Command: perimbox
Param?res courants : PERIMCONV = 1 PERIMPREC = 4
Erreur: too many arguments
Command: totalarea Unknown command "TOTALAREA".  Press F1 for help.
Command: areabox ; error: no function definition: C:TOTALAREA
What's the problem?
Please Help me!
V-Man
Re: TotalArea, TotalPerim Lisp Error
« Reply #1 on: February 01, 2017, 02:30:30 PM »
Works for me! :yes:
HasanCAD
« Reply #2 on: February 02, 2017, 02:25:41 AM »
Maybe because of tustedpath
- Add the lisp path to trustedpath
- Move the lisp to another folder then run
asami486
« Reply #3 on: February 03, 2017, 07:04:58 PM »
I use AutoCAD2010. But they don't works for me.
I changed the folder of Lisp and then they don't works for me.
What's the problem...??
gile
  • Marseille, France
« Reply #4 on: February 04, 2017, 10:15:00 AM »
I tried on an old AutoCAD 2010 (Windows XP 32 bits) and it works as expect.
If you're using Windows 7 or upper, maybe you have to "Unblock" the zip and or  the lsp files (right clic > Properties > General > Unblock).
Andrea
« Reply #5 on: February 06, 2017, 11:41:05 PM »
maybe this can help..
TADD
Keep smile...
