Author Topic: How does Editor shows the message immediately?  (Read 6929 times)
MickD
Re: How does Editor shows the message immediately?
« Reply #15 on: September 13, 2016, 11:06:59 PM »
What happens if you uncomment the ed.WriteMessage?
On Bricscad it works as expected, i.e. it writes to command prompt as well as increasing the progress meter.
- John Carmack
"Everything that is possible demands to exist"
- Gottfried Wilhelm von Leibniz
xys1995
  • Mosquito
« Reply #16 on: September 13, 2016, 11:24:10 PM »
Can't be listed one by one.
Chumplybum
« Reply #17 on: September 15, 2016, 01:50:58 AM »
I'm still unsure what you're trying to achieve... do you want the message to display the percentage complete in one line only, or display a new line for each percentage complete? Using environment.newline might be what you're after.
using this:
For counter As Integer = 1 To 100
            ed.WriteMessage("\n{0}", counter)
        Next
i get:
\n1\n2\n3\n4\n5\n6\n7\n8\n9\n10\...
using this:
            ed.WriteMessage(String.Format("{0}count is {1}", Environment.NewLine, counter))
        Next
i get:
count is 1
count is 2
count is 3
count is 4
count is 5
count is 6
count is 7
count is 8
count is 9
count is 10
using this:
            ed.WriteMessage(String.Format("{0}count is {1}", vbCr, counter))
        Next
you'll get a running percentage, but as mentioned previously you'll need to use 'DoEvents' so the command line can be updated
