Author Topic: thaw layer in viewport  (Read 2350 times)
danny
« on: May 13, 2005, 09:07:58 PM »
I trying to right a script to thaw a layer within the view port.  this is what i have
_.mspace
-layer
thaw
A-f2|A-ANNO-KAIS-048
qsave
the problem is that "thaw" does not thaw the layer in that viewport.  Is their a command to do this or is lisp necessary?
« Reply #1 on: May 13, 2005, 11:37:44 PM »
You will need to use the vplayer command not the _layer command.
Not exactly sure how you are trying to use this, in a script or macro?
"vplayer" "t" "A-f2|A-ANNO-KAIS-048" "current" ""
danny
« Reply #2 on: May 16, 2005, 02:46:31 AM »
I wanted to use it in a script.  I've got 100 or so drawings that this layer has to thawed in.  I wondering now.. if theirs two or more viewports in a drawing,  the script won't work??
nivuahc
« Reply #3 on: May 16, 2005, 07:15:09 AM »
As a script, no, but you can write a Lisp routine that will do the trick and call the Lisp routine with your script.
« Reply #4 on: May 16, 2005, 07:38:11 AM »
I think you can use the ALL option and still use in a script.
Please confirm.
vplayer
t
all
CADaver
« Reply #5 on: May 16, 2005, 09:01:03 AM »
As Charles pointed out the ALL option in vplayer will make the change to all the viewports in the CURRENT layout tab.  you'll need lisp if you use multiple layout tabs.
« Reply #6 on: May 16, 2005, 09:26:24 AM »
Correct me if I'm wrong but the only restriction for vplayer is that you be
in paper space when you execute the command and it changes ALL viewports in ALL tabs.
So this is what you need:
TileMode
0
vplayer
t
all
CADaver
« Reply #7 on: May 16, 2005, 09:31:27 AM »
You're correct, Charles.  The last time I checked we were beta slammin' R2000, it didn't work on multi-tabs then and i never went back to verify.  Thanks for the heads up.
nivuahc
« Reply #8 on: May 16, 2005, 12:18:34 PM »
I stand (actually, I'm sitting, but you get the idea) corrected! :)
Good one CAB!
danny
« Reply #9 on: May 16, 2005, 02:55:56 PM »
thanks guys..
