Author Topic: (AutoLISP the language) ARITHMETIC the AutoLISP way  (Read 2158 times)
« on: June 17, 2016, 09:55:04 AM »
My intentions of this thread, and others, is to show the basics of using the AutoLISP programming language in AutoCAD.
I am basically following the book AutoLISP Programming Principles and Techniques by Rod Rawls and Mark Hagen.
https://www.amazon.com/Autolisp-Programming-Principles-Rod-Rawls/dp/1566371961?ie=UTF8&*Version*=1&*entries*=0
Please ask lots of questions.
If you are an experienced programmer please help by adding additional exercises.
Thanks!
Re: (AutoLISP the language) ARITHMETIC the AutoLISP way
« Reply #1 on: June 17, 2016, 10:14:45 AM »
Basic math: 1 + 2 = 3
AutoLISP function: (+ 1 2) Make note of the spaces in the function.
1 + 2 + 3 = 6
(+ 1 2 3) = 6
3 - 1 = 2
(- 3 1) = 2
(- 20 10 5) = 5
(- 50 -5) = 55
1 * 2 = 3
(* 1 2) = 3
(* 10.525 25.125) = 264.441
(* 50.2 20 2.133) = 2141.53
16 ÷ 2 = 16
(/ 16 8) = 2
(/ 16 8.0) = 2.0
« Last Edit: June 17, 2016, 10:18:58 AM by Mark »
snownut2
  • Bricscad 22 Ultimate
« Reply #2 on: June 17, 2016, 10:17:00 AM »
except for 1+ or 1-   :2funny:
Sorry couldn't help it, in LISP there's always a catch.
« Reply #3 on: June 17, 2016, 10:19:44 AM »
Show us an example please.
snownut2
« Reply #4 on: June 17, 2016, 10:22:00 AM »
ok
  1.
  2. (1+ 2) = 3
  3. (1- 2) = 1
  4.
  5.
I usually use these in a while loop if i am counting either up or down, example.
  1. (setq cnt 0)
  2. (while (< cnt 20)
  3.   ..............
  4.   (setq cnt (1+ cnt))
  5. )
  6.
« Last Edit: June 17, 2016, 10:28:07 AM by snownut2 »
« Reply #5 on: June 17, 2016, 10:35:31 AM »
More advanced math. From the book
18 - [(3 + 6 + 9) ÷ (9 - 6)] - 12
Work from the deepest levels out.
(+ 3 6 9) (- 9 6)
(/ (+ 3 6 9) (- 9 6))
(- 18 (/ (+ 3 6 9) (- 9 6)))
(- (- 18 (/ (+ 3 6 9) (- 9 6))) 12)
« Reply #6 on: June 17, 2016, 10:45:26 AM »
Using arithmetic on the command line.
Command: OFFSET
Current settings: Erase source=No  Layer=Source  OFFSETGAPTYPE=0
Specify offset distance or [Through/Erase/Layer] <Through>: (* 0.235 15)
3.525
ribarm
  • Marko Ribar, architect
« Reply #7 on: June 17, 2016, 12:13:44 PM »
The topic that may be of interest, at least when arithmetic is an issue...
https://www.theswamp.org/index.php?topic=51268.0
M.R. on Youtube
roy_043
  • BricsCAD 18
« Reply #8 on: June 17, 2016, 02:26:48 PM »
... Maybe using CODE tags is a good idea...
Small addition: Negation:
(- 1) => -1
(- -1) => 1
rkmcswain
« Reply #9 on: June 17, 2016, 06:49:45 PM »
Command: OFFSET
3.525
Note that you must include one real number if you want a real number result.
Example:
Command: OFFSET
Specify offset distance or [Through/Erase/Layer] <Through>: (/ 15 4)
3
***compared to ***
Command: OFFSET
Specify offset distance or [Through/Erase/Layer] <Through>: (/ 15 4.0)
3.75
Peter2
« Reply #10 on: June 18, 2016, 05:38:01 AM »
Peter
BricsCAD V23
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #11 on: June 18, 2016, 07:56:30 AM »
Mark was just making sure you were awake Peter .. well done.
Called Kerry in my other life
I live at UTC + 13.00
