Author Topic: Question about Side Database  (Read 1967 times)
pBe
« on: May 09, 2016, 12:43:29 PM »
I read about "side database" here -> http://adndevblog.typepad.com/autocad/2012/07/using-readdwgfile-with-net-attachxref-or-objectarx-acdbattachxref.html
and a c# code from Jeff H. -> https://www.theswamp.org/index.php?topic=31863.msg411012#msg411012 to which i added a line user prompt....
      PromptStringOptions Xrefsource = new PromptStringOptions("Enter Source: ");
            Xrefsource.AllowSpaces = true;
            PromptResult xrefRes= acDoc.Editor.GetString(Xrefsource);
            PromptStringOptions XrefTarget = new PromptStringOptions("Enter Target: ");
            XrefTarget.AllowSpaces = true;
            PromptResult hostRes = acDoc.Editor.GetString(XrefTarget);
            string xrefPath = (xrefRes.StringResult);
            string hostPath = (hostRes.StringResult);
in place of the hard coded path and refname.
& Because of my limited knowledge in .NET, i invoke the C# code from a lisp routine
(foreach itm '(a list of dotted pair)
  (command "_AttachXref" (car itm) (cadr itm))
True enough it works as advertised.
Also found this useful link http://adndevblog.typepad.com/autocad/2012/12/binding-external-references.html
Question: Will they work together? Xref bind and side Database. Just need to know if its doable before i pursue this
On a side note. I keep reading about learning basic .Net programming first before dive into Autocad .NET API. you know what.. You guys are absolutely  right :)
« Last Edit: May 10, 2016, 12:01:20 AM by pBe »
nobody
  • .net stuff
Re: Question about Side Database
« Reply #1 on: May 09, 2016, 04:00:29 PM »
Binding in a side database definitely works.
This might work for what you need though:
https://apps.autodesk.com/ACD/en/Detail/Index?id=1241479836291517004&appLang=en&os=Win32_64
pBe
« Reply #2 on: May 12, 2016, 02:24:01 AM »
Binding in a side database definitely works. ...
Thank you for the confirmation.
Code - C#: [Select]
  1. (foreach itm '(a list of dotted pair)
  2.  (command "_AttachXref" (car itm) (cadr itm))
What it does right now is, step in "_AttachXref" , do the thing then step out. multiple call that is
How do you pass a list to a .NET program?  Is there a way to run the list inside "_AttachXref" ?
gile
  • Marseille, France
« Reply #3 on: May 12, 2016, 02:50:17 AM »
While using side Database, you cannot access the editor so you cannot invoke commands (the same as using ODBX with LISP).
If you think you're now enough comfortable with the .NET environment to learn the AutoCAD API, you need to forget your LISP knowledge and think "how can I do this with .NET" rather than "how do I did this with LISP".
pBe
« Reply #4 on: May 12, 2016, 03:38:40 AM »
While using side Database, you cannot access the editor so you cannot invoke commands (the same as using ODBX with LISP)...
Got it.
Might as well :)  Time to hit the books.
Thank you Gile
