Author Topic: Adding a function…  (Read 1168 times)
MeasureUp
Adding a function…
« on: April 21, 2016, 12:05:39 AM »
Suppose I have several "vlx" files in my usb drive "J". I now would like to add a specified function (e.g. "ABC") when any of my commands is executed.
I don't want to rewrite my codes by adding (ABC) to the end of each my routine.
I prefer to write a separate lisp file and autoload it when AutoCAD starts.
(if (any of my commands is executed)
(load the specified function "ABC")
); end of if
Can it be done?
Your helps are much appreciated.
hugha
Re: Adding a function…
« Reply #1 on: April 21, 2016, 12:35:09 AM »
Been a while, but perhaps ...
(load strcat(the specified function "ABC"))
); end of if
Ok, I completely misread OP's intention. :nerdyembarassed:
« Last Edit: April 21, 2016, 07:36:43 AM by hugha »
« Reply #2 on: April 21, 2016, 01:19:46 AM »
It depends what your function ABC has within it, but there is a lisp reactor.  Maybe you can use that, and if the name is something you recognize, then run your function afterwards.  It seems like there are examples of lisp reactors here.  Just search for vlr-lisp-reactor.
MeasureUp
« Reply #3 on: April 22, 2016, 02:03:30 AM »
Thanks Tim.
I found a thread commented by Lee:
https://www.theswamp.org/index.php?topic=41760.msg468782#msg468782
Sorry, I know nothing about "reactor". Can you explain it for my case? Thanks.
BTW with my question the function which I would like to load can be simplified as
(prompt "\n\nTask has been completed.")(princ)I don't want to get you confused now.
« Reply #4 on: April 23, 2016, 08:14:10 AM »
Reactors take a lot of time and understanding to explain, and I do not have the time right now and maybe not the knowledge to explain it well.  It has been a long time since I look into reactors.
Here is a file I wrote a long time ago that shows a Lisp reactor.  It is a counting reactor for Lisps called during a session of AutoCAD.  Hopefully it can help you.
Sorry.  Maybe someone with more skills with reactors can help.
Here is a link to the thread that the code was posted before.  Not a lot of explaining in it though.  I added the missing sub talked about in the thread link, so the file should work fine now.  Untested though.
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-usage-tracking/td-p/1383527/highlight/true
ur_naz
  • Made in Ukraine
« Reply #5 on: April 27, 2016, 11:36:13 PM »
Take a look on autoload function
