Author Topic: Filter list  (Read 1038 times)
Robert98
Filter list
« on: April 06, 2016, 09:16:58 AM »
Hello everyone.
I want to filter a list of strings just like the filter function in VB script ,but when I launch the code, the original list shows up.
Can anyone tell me what i'm doing wrong . Here is my code:
(defun c:Filter   (/ lst1 elem elem2)
  (setq lst1 '("Study" "moon" "teacher" "ball"))
  (foreach elem   lst1
    (setq elem2 (vl-string->list elem))
    (if   (= (member '(ascii "m") elem2) nil)
      (vl-remove elem lst1)
      (princ "\n")
  (princ lst1)
When I fire up the filter command ,I expect to get ("Study" "teacher" "ball") which is a list without strings that contain "m" letter in their structure.
Re: Filter list
« Reply #1 on: April 06, 2016, 10:03:52 AM »
When you remove the element, you need to set your lst1 variable like so:
  1. (setq lst1 (vl-remove elem lst1))
Also ...
  1. (member '(ascii "m") elem2)
will always return nil because of the ' ( quote ).
This can also be achieved using wcmatch like so ( keep in mind wcmatch is case sensitive ):
  1. (vl-remove-if '(lambda (x) (wcmatch x "*m*")) '("Study" "moon" "teacher" "ball"))
dgorsman
Re: Filter list
« Reply #2 on: April 06, 2016, 10:14:24 AM »
Put another way, (vl-remove ...) returns a modified copy of the list and leaves the original intact.  Most LISP functions operate that way.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
ChrisCarlson
Re: Filter list
« Reply #3 on: April 06, 2016, 10:26:08 AM »
  1. (defun CC:remove ( lst1 wc /  )
  2.         (setq lst2
  3.                 (vl-remove-if
  4.                         '(lambda (x)
  5.                                 (wcmatch x wc))
  6.                         lst1
  7.                 )
  8.         )
  9. )
  10.
  11.
  12. (defun c:remove_test ( / lst)
  13.         (setq lst '("Study" "moon" "teacher" "ball"))
  14.         (CC:remove lst "*m*")
  15. )
  16.
Robert98
Re: Filter list
« Reply #4 on: April 06, 2016, 10:54:44 AM »
Thank you everyone for all your replies.
I'll try what you suggested and i'll provide you with more details on the results.
