Author Topic: BMP2DCL  (Read 1933 times)
amc.dicsac
  • Autocad 2008
BMP2DCL
« on: March 24, 2016, 08:50:57 PM »
Hello
Is there any way to convert .bmp files to add as vector image .dcl
Example:
  145 155 155 155 155 155 155 155 155 155 155 155 155 155 155 145
                155 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 155
                155 -15 145 145 163 163 163 163 163 163 163 163 145 145 -15 155
                155 -15 254 254 -15 -15 -15 254 254 254 254 254 254 254 -15 155
                155 -15 145 153 153 153 153 153 163 163 153 153 163 145 -15 155
                155 -15 -15 -15 250 250 250 -15 -15 -15 254 251 -15 -15 -15 155
                155 -15 145 163 153 153 153 153 153 153 153 153 163 145 -15 155
                155 -15 -15 -15 -15 253 250 250 250 250 250 -15 -15 -15 -15 155
                155 -15 145 145 163 153 153 153 153 153 153 153 163 145 -15 155
                155 -15 -15 -15 -15 -15 018 -15 -15 -15 252 250 -15 -15 -15 155
                155 -15 145 145 145 163 153 163 145 145 153 153 163 145 -15 155
                155 -15 145 145 145 145 145 145 145 145 145 145 145 145 -15 155
                252 155 155 155 155 155 155 155 155 155 155 155 155 155 155 252
                254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254
« Last Edit: March 24, 2016, 08:54:24 PM by amc.dicsac »
<a href="http:/http://axprogramlisp.blogspot.pe" class="bbc_link" target="_blank">By Alexander Castro</a>
roy_043
  • BricsCAD 18
mailmaverick
Re: BMP2DCL
« Reply #2 on: April 15, 2016, 06:37:04 AM »
Kindly see following link :-
http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-1FD95F7C-0EBD-4841-9BE8-7C1EC210548D
Also I have implemented the same in Excel VBA. Please see the file attached.
I am using AutoCAD 2014. Hence, in the VBA module, in the line :
Set colorv = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor.19"), kindly change the number 19 to the version of your AutoCAD. Also I have seen that this module works only when my AutoCAD is open and any file (even a blank file) is opened. Kindly check at your end and let me know.
« Last Edit: April 15, 2016, 06:48:32 AM by mailmaverick »
amc.dicsac
  • Autocad 2008
Re: BMP2DCL
« Reply #3 on: April 22, 2016, 10:28:39 AM »
Hello such thanks for your answer. I have a problem when I open I get this error excell tell me there is a solution for that.
mailmaverick
Re: BMP2DCL
« Reply #4 on: April 30, 2016, 06:38:27 AM »
In Excel, Press Alt+F11, a new window (Microsoft Visual Basic for Applications) will open.
Go to Tools --> References Kindly Tick options given in attached image.
d2010
Re: BMP2DCL
« Reply #5 on: April 30, 2016, 01:16:04 PM »
Hello
Example:
:whistling:
Our solution (bigs  images as JPEG )  from  my team,I converted  3 images  (pisicute to auto-lisp.)
You  unzip  all files from   "MSJDBC"  to C:\   or C:\
You run autocad.exe ,
You  enter  the  command "appload"
You run the  file  pp_cat1.lsp  from folder  C:\VLAXCOMPIL\0User\pp_cat1.lsp
Q2<enter>
PS: AutoCAD  love animals, cat, dog, lions?>
« Last Edit: May 05, 2016, 10:28:08 AM by d2010 »
