Author Topic: Dynamic Title Block Revision Box  (Read 7388 times)
Willie
  • Going nowhere slowly
« on: March 15, 2016, 07:47:27 AM »
I thought I must share.
I have been thinking of  incorporating multiline attributes in a revision block, where the size of the frame around the text can easily be adjusted and that the attributes would stay in the center.
I came up with the attached, but the help came from this: http://www.cad-notes.com/how-to-keep-attributes-at-dynamic-block-center/.
« Last Edit: March 15, 2016, 10:49:09 AM by Willie »
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
lamarn
Re: Dynamic Title Block Revision Box
« Reply #1 on: March 15, 2016, 09:54:53 AM »
Willie, that is a really nice piece of dynamic block work!
Thanks for sharing. I have nothing more to add... i'm just going to use it :)
ChrisCarlson
« Reply #2 on: March 16, 2016, 01:21:38 PM »
Would time have been better spent simply using an AutoCAD table? The only difference is that you are editing the cell contents within the properties window vs within the individual cells.
« Reply #3 on: March 16, 2016, 01:59:08 PM »
or a sheet set table....
Willie
« Reply #4 on: March 16, 2016, 02:21:46 PM »
Maybe yes, but it's part of a title block.
