Author Topic: GRREAD - OSNAP  (Read 1951 times)
amc.dicsac
  • Autocad 2008
GRREAD - OSNAP
« on: March 14, 2016, 12:34:35 PM »
Hi, how are you:
I have a lisp that inserts a block in which'm using quite the GRREAD I wonder if when the previous insercción block the GRREAD I can keep activated osnap :opps:
    (defun c:test (/ bname key grr ip lastpt ent)
      (setvar "cmdecho" 0)
      (while
        (not (or (eq "" (setq bname (getstring t "\nBlock to Insert: "))) (tblsearch "BLOCK" bname)))
         (princ "\nBlock not found.")
      (while            ;  exit on ENTER or picked point
        (cond ;;=====================================================
         ((eq 2 (car (setq grr (grread t 7 0)))) ; keyboard input
          (setq key (cadr grr))
          (cond ;;-------------------------------------------
           ((= key 13)      ; ENTER- where done here
            (and ent (entdel ent))
            (princ "\nUser Quit.")
            nil         ; exit loop
           ((member (chr key) '("H" "h")) ; Word entry  'Help'
                   ;(Display_Help) ; your alert box routine
            t         ; stay in loop
           ((member (chr key) '("I" "i")) ; Insert with OSNAP
            (vl-cmdf "_.move" ent "" "_non" lastpt)
            (while (= (logand (getvar "cmdactive") 1) 1) (command pause))
            nil         ; stay in loop
           ((member (chr key) '("L" "l")) ; Left or CCW
            (vl-cmdf "_.rotate" ent "" "_non" ip 90.0)
            t         ; stay in loop
           ((member (chr key) '("R" "r")) ; Right or CW
            (vl-cmdf "_.rotate" ent "" "_non" ip -90.0)
            t         ; stay in loop
           ((member (chr key) '("B" "b")) ; Basepoint
            (vl-cmdf "_.move" ent "" "_non" (getpoint "\nPick New Basepoint: ") "_non" ip)
            t         ; stay in loop
           ((princ "\nInvalid Keypress.") (princ (strcat msg str)))
          )            ; end cond
         ((eq 3 (car grr))      ; point picked, make final star
          (setq ip (cadr grr))
          nil            ; exit
         ((eq 5 (car grr))      ; point from mouse, update object
          (if (null lastpt)      ; first time through
            (progn (setq lastpt ip)
              (vl-cmdf "_.-insert" bname "_S" 1.0 "_R" 0.0 "_non" ip)
              (setq ent (entlast))
          (if (> (distance ip lastpt) 0.00001)
            (vl-cmdf "_.move" ent "" "_non" lastpt "_non" ip)
          (setq lastpt ip)
        )               ; end cond
      )               ; while
      (redraw)
« Last Edit: March 14, 2016, 12:39:25 PM by amc.dicsac »
<a href="http:/http://axprogramlisp.blogspot.pe" class="bbc_link" target="_blank">By Alexander Castro</a>
roy_043
  • BricsCAD 18
Re: GRREAD - OSNAP
« Reply #1 on: March 14, 2016, 03:26:10 PM »
amc.dicsac
  • Autocad 2008
Re: GRREAD - OSNAP
« Reply #2 on: March 14, 2016, 04:19:34 PM »
Hi, how are you
  REPLACE SOME OF MY LINES WITH LISP FORUM THAT SENT ME BUT HAVE NOT WANT WHAT I WANT TO GET TO KNOW ME IF YOU CAN PLEASE AMEND
(defun folder1 (a / cm cn)
;Dimensiones necesarias para la image_tile: Ancho:15; Altura: 15
  (setq cm 15 cn 0)
  (start_image a)
  (foreach x '(
       ( 252 251 251 251 251 251 251 251 251 251 252 9 9 9 9 9)
       ( 250 253 253 253 253 253 253 253 253 252 251 9 9 9 9 9)
       ( 250 251 253 253 253 253 253 253 253 253 252 251 9 9 9 9)
       ( 250 250 253 9 9 9 253 253 253 253 253 250 8 9 9 9)
       ( 250 253 8 251 251 251 9 9 9 9 9 253 251 9 9 9)
       ( 250 253 253 253 253 252 250 250 250 250 250 250 252 9 9 9)
       ( 250 254 254 254 254 9 250 250 250 250 252 9 9 9 9 9)
       ( 8 250 250 250 250 252 9 9 9 9 9 9 9 9 9 9)
       ( 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9)
       ( 9 9 9 9 9 18 18 18 9 9 18 18 18 18 9 9)
       ( 9 9 9 9 9 18 7 18 9 18 7 7 7 9 18 9)
       ( 9 9 9 9 9 18 7 18 18 7 7 7 7 7 7 18)
       ( 9 9 9 9 9 18 7 18 9 18 9 7 7 7 18 9)
    (foreach y x (apply 'fill_image (list cn cm 1 1 y)) (setq cn (1+ cn)))
    (setq cm (1- cm) cn 0)
  (end_image)
(defun seleccionate (a / cm cn)
  (setq cm 15 cn 0)
  (start_image a)
  (foreach x '(
       ( 9 9 9 9 250 251 251 251 251 251 251 251 251 251 251 251)
       ( 9 9 9 9 250 9 9 9 9 9 253 9 9 9 253 251)
       ( 9 9 9 9 250 254 254 254 254 145 159 254 254 254 9 251)
       ( 9 9 9 9 250 9 9 9 155 159 159 167 9 9 253 251)
       ( 9 9 9 9 9 9 9 157 177 156 169 159 253 9 253 251)
       ( 18 18 18 18 18 18 253 253 9 156 159 156 167 254 253 251)
       ( 18 7 7 7 7 18 253 253 253 148 177 253 253 253 253 251)
       ( 18 18 18 18 18 18 253 253 157 148 153 253 253 253 253 251)
       ( 9 9 18 18 9 253 253 145 156 177 253 253 253 253 252 251)
       ( 9 18 7 7 18 9 177 156 167 253 253 253 253 253 252 251)
       ( 18 9 7 7 7 18 252 253 253 253 253 253 253 253 252 251)
       ( 18 7 7 7 7 18 9 252 251 251 251 251 252 9 253 251)
       ( 18 7 7 7 7 18 9 251 7 7 7 254 251 250 250 252)
       ( 18 7 7 7 9 18 7 252 251 251 251 251 252 7 7 7)
       ( 9 18 7 7 18 9 9 9 9 9 9 9 9 9 9 9)
       ( 9 9 18 18 9 9 9 9 9 9 9 9 9 9 9 9)
  (end_image)
(defun var (blist / m) (setq alcup nil racup nil)
 (defun alex(pa pb)
   ((> pa pb)t)
   ((= pa pb )t)
   (t nil)
 (foreach m blist
  (while (and racup(alex m(car racup)))(setq alcup(cons(car racup)alcup)racup(cdr racup)))
   (while (and alcup(alex(car alcup)m))(setq racup(cons(car alcup)racup)alcup(cdr alcup)))
   (setq racup(cons m racup))
 (append(reverse alcup)racup)
(defun saveVars()
  (setq esc1 (get_tile "esc1"))
  (setq esd1(atoi(get_tile "ess1")))
  (setq esd2(atoi(get_tile "ess2")))
  (setq esd3(atoi(get_tile "ess3")))
  (setq esd4(atoi(get_tile "ess4")))
  (setq esd5(atoi(get_tile "ess5")))
  (setq blkList(list)) ;;;--- Setup a list to hold the selected items
  (setq ignlist(get_tile "bloqlist"))   ;;;--- Save the list setting
  (setq count 1)   ;;;--- Setup a variable to run through the list
  ;;;--- Cycle through the list getting all of the selected items
  (while (setq fila (read ignlist))
    (setq blkList(append blkList (list (nth fila bloList))))
    (while
      (and
        (/= " " (substr ignlist count 1))
        (/= ""  (substr ignlist count 1))
      (setq count (1+ count))
    (setq ignlist (substr ignlist count))
(defun blokinf ()
  (setq bloList(list))   ;;;--- Set up an empty list
  (if (findfile "1-DWG-TOMACORRIENTES.txt")   ;;;--- Open the text file
      (if (setq ruta(open (findfile "C:/Program Files/AutoCAD 2008/1-DWG-TOMACORRIENTES.txt") "r"))
          (read-line ruta)  ;;;--- Skip the first three lines
          (while (setq pa (read-line ruta))           ;;;--- Read the lines of data in the text file
            (setq bloList             ;;;--- Add the data to the list
              (append
                bloList
                (list (list pa))
          (close ruta)          ;;;--- Close the file.
   bloList  ;;;--- Sort the list
;;;;;;;;;;;;;;;;;;;;;; End of Bloque listing ;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun c:E1 (/ esc1$ bloqlist$ Return#  bname key grr ip lastpt ent)
(if (not *E1@) (setq *E1@ (list nill "" "")))
(setq esc1$ (nth 1 *E1@)
      bloqlist$ (nth 2 *E1@))
(setq bloList(blokinf))   ;;;--- Get the layer names
  (if bloList   ;;;--- If a master list was found
      (setq dcl_id (load_dialog "C:/Program Files/AutoCAD 2008/Support/CADMASTER 2008/RUTINAS/INSERT-1.dcl"))       ;;;--- Load the DCL file
     (if (not (new_dialog "INSERTA" dcl_id "" (cond (*screenpointE1*) ('(-1 -1)))))       ;;;--- See if the dialog box is already loaded
        (princ "\nLisp Cancelado VERIFICAR FALLA")
          (exit)
      (folder1 "load") ;;;;AGREGAR LINEA PARA CARGAR FOTOS
      (seleccionate "save") ;;;;AGREGAR LINEA PARA CARGAR FOTOS
      (setq bloNames(list))       ;;;--- Get the layer names
      (foreach pa bloList
        (setq bloNames(append bloNames(list (car pa))))
      ;;;--- Add the layer names to the dialog box
      (start_list "bloqlist" 1)
      (mapcar 'add_list bloNames)
      (end_list)
      (set_tile "esc1" esc1$)
      (set_tile "bloqlist" bloqlist$)
      (action_tile "esc1" "(setq esc1$ $value)")
      (action_tile "bloqlist" "(setq bloqlist$ $value)")
      (action_tile "cancel" "(setq *screenpointE1* (done_dialog 1))")
      (action_tile "accept" "(saveVars)(setq *screenpointE1* (done_dialog 2))")
      (action_tile "save" "(done_dialog 3)")
      (action_tile "load" "(actualiza)")
      (action_tile "centrado" "(done_dialog 5)")
      (setq ddiag (start_dialog))
      (unload_dialog dcl_id)
      (setq *E1@ (list nil esc1$ bloqlist$))
      (if (= ddiag 3) (carga))
      (if (= ddiag 5) (centroide))
      (if (= ddiag 4) (actualiza))
      (if (= ddiag 1) (prompt "\nPrograma Cancelado..."))
      ;;;--- If the "Okay" button was pressed
      (if (= ddiag 2)
          ((= esc1 "ess1") (setq pv 2))
          ((= esc1 "ess2") (setq pv 1))
          ((= esc1 "ess3") (setq pv 1.5))
          ((= esc1 "ess4") (setq pv 0.5))
          ((= esc1 "ess5") (setq pv 20))
          ((= esd1 1)(setq pv 2))
          ((= esd2 1)(setq pv 1))
          ((= esd3 1)(setq pv 1.5))
          ((= esd4 1)(setq pv 0.5))
          ((= esd5 1)(setq pv 20))
          (if (> (length blkList) 0)
              (foreach pa blkList
                (setq MIL (getvar "insunits"))
                (setvar "insunits" 4)
         (setq mxb (strcat  "\nGirar [I]zquierda / [D]erecha\n" "Ubicacion [T]emporal, Punto [B]ase: "))
            ;; keyboard input
                (princ "\n**Cancel**.")
                nil ; exit loop
                 (vl-cmdf "_.insert" (car pa) )
                  (command pause)
                   t ; stay in loop
               ((member (chr key) '("T" "t")) ; Insert with OSNAP
                   nil         ; stay in loop
               ((member (chr key) '("I" "i")) ; Left or CCW
                 t ; stay in loop
               ((member (chr key) '("D" "d")) ; Right or CW
                 t ; stay in loop
                 (vl-cmdf "_.move" ent "" (getpoint "\n>> Especifica punto base: ") ip)
              (princ mxb)
                 t         ; stay in loop
               ((princ "\nTecla Invalidada.") (princ mxb))
             ) ; end cond
             ; (setq ip (cadr grr))
             (setq cursor_position (cadr grr))
             nil ; exit
             ;;(setq ip (cadr grr))
(setq ID_point
                 ((osnap cursor_position "_end,_mid,_int")) ;"_end,_mid,_int"
                  (cursor_position)
                 ;;(setq lastpt ip)
(setq lastpt ID_point)
                 (princ mxb)
                 (vl-cmdf "_.insert" (car pa) "_S" pv "_R" 0.0 "_non" ID_point)
; (vl-cmdf "_.insert" (car pa) "_S" pv "_R" 0.0 ID_point)
             ; (if (> (distance ip lastpt) 0.00001)
(if (> (distance ID_point lastpt) 0.00001)
              ; (vl-cmdf "_.move" ent "" "_non" lastpt "_non" ip)
  (vl-cmdf "_.move" ent "" "_non" lastpt "_non" ID_point)
               ;;;(vl-cmdf "_.move" ent "" lastpt  ip)
             ; (setq lastpt ip)
          )   ; end cond
        )     ; while
        (redraw)
                (command "explode" ent "")
                (setvar "insunits" MIL)
                (setvar "cmdecho" 1)
  (princ))
(defun carga (/ Conjunto Ubicacion)
(defun AUX_SelectSaveFile (Extension / Directorio EntNombre EntNuevoName)
(setq Nombre (vla-get-Effectivename(vlax-ename->vla-object Conjunto )))
;;;(setq Blockname (substr Nombre 11))
;;;(setq Prefijo "1-DEU-DWG ")
(setq EntNombre (strcase Nombre))
(setq EntNuevoName (vl-filename-base (substr (vl-filename-mktemp (strcat EntNombre Extension)) 1 3)))
(setq Liga (strcat EntNombre EntNuevoName))
(setq Liga1 (strcat "C:/Program Files/AutoCAD 2008/Support/CADMASTER 2008/BLOCKS/TOMACORRIENTES-1/" Liga))
((setq Directorio (getfiled "Guardar Bloque version 1.3 A.E.CAD 2014" Liga1 Extension 1))
(setq EntNombre (strcat (vl-filename-directory Directorio) "\\"))))
          Directorio )
(if (setq Conjunto (car (entsel "\nSelecciona bloque a guardar: "))
                  EntPto  (cdr (assoc 10 (entget Conjunto))))
((setq Ubicacion (AUX_SelectSaveFile "dwg"))
(command "_undo" "_begin")
(if (findfile Ubicacion)
(vl-cmdf "_.-WBLOCK" Ubicacion "_Y" "" EntPto Conjunto "")
(vl-cmdf "_.-WBLOCK" Ubicacion "" '(0 0 0) Conjunto "")
(startapp "explorer" (strcat "/n,/e," Ubicacion))
(command "_undo" "_end")
(setvar "cmdecho" 1))))
(alert "\nMueva el bloque al eje 0,0,0 ")
(princ))
(defun actualiza (/ Conjunto Ubicacion)
(setq EntNombre "C:/Program Files/AutoCAD 2008/1-DWG-TOMACORRIENTES.txt")
((setq Directorio (getfiled "Abrir Bloque version 1.3 A.E.CAD 2014" (strcat EntNombre EntNuevoName) Extension 4))
      Directorio)
((setq Ubicacion (AUX_SelectSaveFile "txt"))
(princ))
roy_043
  • BricsCAD 18
Re: GRREAD - OSNAP
« Reply #3 on: March 15, 2016, 08:39:35 AM »
I am sorry, but you will have to do that yourself. :evil:
squirreldip
Re: GRREAD - OSNAP
« Reply #4 on: March 16, 2016, 05:01:04 PM »
(alert (vl-list->string (list 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 95 95 32 10 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 95 32 44 95 95 95 44 45 39 34 44 45
                              61 45 46 32 10 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 95 95 44 45 45
                              32 32 95 32 32 95 44 45 39 95 41 95 32 32 32 32 40 34 34 96 39 45 46 95 92 32 32 96 46 32 10 32
                              32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 95 44 39 32 32 32 32 95 95 32 32 124 44 39 32 32 44
                              45 39 32 32 95 95 41 32 32 32 32 44 45 32 32 32 32 32 32 32 32 32 32 47 46 32 32 124 32 10 32 32
                              32 32 32 32 32 32 32 32 32 32 44 39 95 44 45 45 39 32 32 32 32 32 32 124 32 32 32 32 32 32 32 32
                              32 32 45 39 32 32 32 32 95 41 47 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 96 92 32
                              10 32 32 32 32 32 32 32 32 44 39 44 39 32 32 32 32 32 32 32 32 32 32 32 32 44 39 32 32 32 32 32
                              32 32 32 32 32 32 32 32 32 44 45 39 95 44 96 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 32 32 32 58 32 10 32 32 32 32 32 32 32 32 44 39 32 32 32 32 32 32 32 32 32 32 44 45 39 32
                              32 32 32 32 32 32 32 32 32 32 32 32 32 44 40 44 45 40 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 32 32 32 32 32 32 32 32 32 32 32 32 58 32 10 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 32 44 39 32 32 32 32 32 32 32 32 32 32 32 32 32 32 44 45 39 32 32 44 32 32 32 32 32 32 32
                              32 95 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 59 32 10 32 32 32
                              32 32 32 32 32 32 32 32 32 32 32 32 32 47 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 44 45
                              46 95 47 96 45 45 45 39 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              47 32 10 32 32 32 32 32 32 32 32 32 32 32 32 32 32 47 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 40 95 95 95 95 41 40 45 45 45 45 46 32 32 41 32 32 32 32 32 32 32 32 32 32 32 32 32 32 44
                              39 32 10 32 32 32 32 32 32 32 32 32 32 32 32 47 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 40 32 32 32 32 32 32 32 32 32 32 32 32 96 46 95 95 44 32 32 32 32 32 32 32 32 32 32 47 92
                              32 32 47 44 32 10 32 32 32 32 32 32 32 32 32 32 58 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 32 32 32 32 32 59 45 46 95 95 95 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 47
                              95 95 92 47 124 32 10 32 32 32 32 32 32 32 32 32 32 124 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 32 32 44 39 32 32 32 32 32 32 32 32 32 32 32 32 96 45 45 46 32 32 32 32 32 32 32 32 32 32
                              32 32 45 44 92 32 32 124 32 10 32 32 32 32 32 32 32 32 32 32 58 32 32 32 32 32 32 32 32 32 32 32
                              32 32 32 32 32 47 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 92 32
                              32 32 32 32 32 32 32 46 95 95 47 32 10 32 32 32 32 32 32 32 32 32 32 32 32 92 32 32 32 32 32 32
                              32 32 32 32 32 32 40 95 95 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 92 32 32 32 32 32 32 32 32 124 95 32 10 32 32 32 32 32 32 32 32 32 32 32 32 32 32 92 32 32 32
                              32 32 32 32 32 32 32 32 32 32 32 44 96 45 44 32 42 32 32 32 32 32 32 32 32 32 32 32 32 32 32 47
                              32 32 32 32 32 32 95 124 44 92 32 10 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 92 32 32 32
                              32 32 32 32 32 44 39 32 32 32 32 32 32 96 45 46 32 32 32 32 32 32 32 32 32 32 44 39 95 44 45 39
                              32 32 32 32 32 32 32 32 92 32 10 32 32 32 32 32 32 32 32 32 32 32 32 32 32 40 95 92 44 45 39 32
                              32 32 32 32 32 32 32 44 39 92 34 41 45 45 44 39 45 39 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              95 95 92 32 10 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 92 32 32 32 32 32 32 32 32 32 32
                              32 32 32 32 47 32 32 32 32 47 47 32 32 44 39 124 32 32 32 32 32 32 32 32 32 32 32 32 44 45 45 39
                              32 32 32 32 96 45 46 32 10 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 96 45 46 32 32
                              32 32 32 32 32 32 96 45 47 32 32 92 39 32 32 32 32 124 32 32 32 32 32 32 95 44 39 32 32 32 32 32
                              32 32 32 32 32 32 32 32 32 32 32 32 32 96 46 32 10 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 32 32 32 32 32 32 32 96 45 46 95 32 47 32 32 32 32 32 32 32 32 32 32 32 32 96 45 45 39 47
                              32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 92 32 10 32 32 32
                              32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 44 39 32 32 32
                              32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 124 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 92 32 10 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 47 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 32 32 32 32 32 32 32 32 124 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 32 32 32 32 32 32 32 92 32 10 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 32 44 45 39 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              32 124 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
                              47 32 10 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 47 32 32 32 32 32 32 32 32
                              32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 124 32 32 32 32 32
                              32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 45 39 32 10)))
