I'm short on time, and not coming up with what I need in a brief search; hope for some help, which I already know that I should already know... The kicker is, that I used to know, as I remember fixing this, just too long ago.
I'm adding a Sanitary Pipe Network -
I need the pipe to end at the inner wall of my structure, but the rule doesn't seem to be applying.
The minimum cover is wrong, or is at least based on something that I don't care about, and need it to be based on the Structure's Rim elevation (rim elevation is showing as correct)... As example, high point of the run should be Structure Rim elevation - (minus) 3.50 FT
Following an Apply Rules, downstream pipes seem to raise themselves, despite needing to be 0.1 drop across structure?
One of my Structure Labels includes a Block which represents the structure number - the Block attribute is ignored, okay, so be it - I've added text component to correct, but the block doesn't show in dragged state, WTF?
TIA
