Author Topic: Command Line and Number of Lines  (Read 4958 times)
Rob...
« on: March 02, 2016, 07:33:09 AM »
Just recently, when I dock my command line I get nine lines displaying. I used to be able to drag an edge to resize it. I seem to have lost that ability and can't find the variable to assign a number of lines.
« Last Edit: March 11, 2016, 05:36:08 PM by Rob... »
CAD Tech
Matt__W
  • I like my water diluted.
Re: Command Line and Number of Lines
« Reply #1 on: March 02, 2016, 07:39:02 AM »
Is your UI locked?
Autodesk Expert Elite
Rob...
« Reply #2 on: March 02, 2016, 07:42:04 AM »
No, everything else is movable, dockable, and resizable.
(I almost misspelled dockable with an "i".)
CAD Tech
TheCADnoob
« Reply #3 on: March 02, 2016, 07:51:28 AM »
Until recently, when I dock my command line I get nine lines displaying. I used to be able to drag an edge to resize it. I seem to have lost that ability and can't find the variable to assign a number of lines.
Are you talking about CLIPROMPTLINES or are you talking about the size of the actual box its self?
To boldly go where spell check has never gone before. | AutoCAD - 2016 | cadnoob.com
Rob...
« Reply #4 on: March 02, 2016, 07:52:55 AM »
The size of the box.
CAD Tech
ChrisCarlson
« Reply #5 on: March 02, 2016, 09:53:58 AM »
Hold control while hovering over the top of command line.
Rob...
« Reply #6 on: March 02, 2016, 09:56:05 AM »
That does nothing.
CAD Tech
Matt__W
« Reply #7 on: March 02, 2016, 10:17:19 AM »
That does nothing.
Try ALT+F4. Any luck?
Rob...
« Reply #8 on: March 02, 2016, 10:20:06 AM »
That does nothing.
That's it!
And I thought I could trust you.
CAD Tech
Rob...
« Reply #9 on: March 11, 2016, 08:30:15 AM »
Reason for not being able to resize:
Command line docked at top.
Solution:
Dock at bottom, re-size, and move to the top.
CAD Tech
« Reply #10 on: March 11, 2016, 09:18:59 AM »
Solution:
That makes me sick just thinking about it.
LOL
DanB
« Reply #11 on: March 11, 2016, 12:14:36 PM »
I too have my command line docked along the top (below the ribbon) and have experienced the same lack of resizing capabilities. I think I've redone it enough times that it's finally holding but it was moving around constantly after a restart. The CUI customization and workspace don't seem to save the desired settings as expected.
« Reply #12 on: March 11, 2016, 12:16:52 PM »
 :thinking:
There is a stupid setting for that...although it isn't always desirable
DanB
« Reply #13 on: March 11, 2016, 03:54:21 PM »
Yep, mines set to save changes. I've even forced saved workspaces to various names then immediately saved over the Named Workspace I want to be current and default.
DanB
« Reply #14 on: March 11, 2016, 03:57:12 PM »
Here's an old link (if it works) https://www.theswamp.org/index.php?topic=41222.msg463812#msg463812
This was my go to for having the command line stay how I wanted it. I just restarted AutoCAD and it's gone rogue again.
