Author Topic: Any Map 3d users here?  (Read 7438 times)
yarnstormer
« on: January 05, 2016, 01:56:31 PM »
I'm mapping county waterlines etc...have traditionally done mapping in cad, but I'd like to do my work so that it can be utilized by GIS dept. GIS says my work can't be used other than to trace.
What does Map 3d do if it does not integrate with GIS? I was able to import shape files etc and it "looks" like an arcmap file. But what about the information I draw in? Is it not any more useful than exporting polylines for the GIS dept to trace over?
I'm campaigning for an all GIS approach but for now I'm asked to have cad as well.
Suggestions?
Re: Any Map 3d users here?
« Reply #1 on: January 05, 2016, 02:36:45 PM »
the level of usefulness is dependant upon
A) accuracy of the source data to cad conversion
is this stuff digitized, or field located (GPS or survey)
B) use of object data to embed and or link the Graphic to database(s)
No reason your MAP data can not successfully export as SDF or SHP files for your GIS department to utilize.
« Reply #2 on: January 05, 2016, 02:51:22 PM »
Nope, none what-so-ever. :)
« Reply #3 on: January 05, 2016, 02:56:42 PM »
on second thoughts
an ideal workflow might be as follows
attach their data source (database) to map session
add to MAP
draw, add the new geometry, and then create NEW records from that geometry
add data records to the database
check in all features
everything is now in their datastore
no reson to export , or import or attempt to merge shp files.
« Reply #4 on: January 05, 2016, 03:06:36 PM »
assuming you have rights/permission to do so. :)
« Reply #5 on: January 05, 2016, 03:10:36 PM »
