Author Topic: Multiple visibility states  (Read 9560 times)
Mirko
« on: December 16, 2015, 02:21:26 PM »
Hi everybody,
I'm writing my firs post :)
Someone is able to explain me, step by step how to use this?
http://www.private.peterlink.ru/poleshchuk/cad/2009/tainypod12e.htm
Because I've creted a complicated dynamic block, and to make it able to work, I must create many visibility states...fortunately on the internet I found this lisp:
I think this would save me a lot of time...but I'm not able to use it... :(
Thank you
Re: Multiple visibility states
« Reply #1 on: December 16, 2015, 02:27:35 PM »
first good work finding The Swamp!
second,
you do not need to use that LISP
open block editor and assign visibility states as desired...
a key point LEAVE everything visible as you create each state
AND THEN
set each state current and adjust/add items that should be visible or NOT to each state....
Mirko
« Reply #2 on: December 16, 2015, 02:54:56 PM »
Hi mjfarrell thank you,
I've creted the dynamic block with the visibility states....I'll explain...I would like to create a block like this...:
https://forums.autodesk.com/autodesk/attachments/autodesk/154/16561/1/Multiple%20Visibility%20States.dwg
I already have all the visibility states cobinations, but I don't know how to add the lookup control ...and so I've founded the lisp...
« Reply #3 on: December 16, 2015, 03:05:58 PM »
from what I can see there is no 'look up' control on that block, only visibility states...
EDIT - yes there is a look up table in that block you linked to,however it does not appear to function without using properties dialogue
what do you want your block to do actually?
« Last Edit: December 16, 2015, 03:09:17 PM by mjfarrell »
« Reply #4 on: December 16, 2015, 03:10:48 PM »
ChrisCarlson
« Reply #5 on: December 16, 2015, 04:24:13 PM »
Holy moley, I could not imagine the number of look up table lines in that block. Basically every option or view is it's own visibility state.
« Reply #6 on: December 16, 2015, 04:29:14 PM »
It is interesting to say the least...
although I am reminded of this
"Just because you can, never means you should"
Mirko
« Reply #7 on: December 18, 2015, 01:08:38 PM »
Okay in this days I've tried, I've started to made it whit the lookup table. Sforunately I've to create 315 visibility states :(...
« Reply #8 on: December 18, 2015, 02:12:58 PM »
or you need other blocks....
why make it that complicated?
Mirko
« Reply #9 on: December 18, 2015, 04:04:26 PM »
I've thinked that, but in this dynamic block I've some data field inserted, and so I would have to redefine 8 blocks for each data field... :-o :-o
I've just vrited here: http://www.theswamp.org/index.php?topic=50645.0 maybe someone has an idea...
Thank you!
lamarn
« Reply #10 on: December 18, 2015, 05:30:53 PM »
There  is Revit which has a lot more options to get smart ass families. I just use other ones..
