Author Topic: AutoCAD Architecture plus Autolisp?  (Read 5702 times)
Peter2
« on: November 18, 2015, 05:57:16 PM »
I know "AutoCAD Vanilla plus Autolisp", but what's about "Architecture" (I never used it ...). Does it works with AutoLisp? Same way as AutoCAD? Worse? Nearly not?
Peter
BricsCAD V23
MexicanCustard
Re: AutoCAD Architecture plus Autolisp?
« Reply #1 on: November 19, 2015, 07:43:34 AM »
Yes, it's just AutoCAD under the hood.  So anything that will work in vanilla will work in the verticals.  There are no VLISP commands for the verticals.  You can interact with some ACA/MEP entities through COM and DXF naming but for the most part you'll need .NET to work with the vertical specific components.
Peter2
« Reply #2 on: November 19, 2015, 07:47:53 AM »
Thanks!
Peter
BricsCAD V23
