Author Topic: vla leaders  (Read 1620 times)
chauhuh
vla leaders
« on: October 29, 2015, 03:17:41 PM »
Hello and thank you for looking.
The goal is to copy the properties of an existing leader and then start the leader command again. I can't seem to convert the object to a vla object in order to get the arrowheadblock.
Thanks!
(defun c:qww (/ s en e vla_s LeaderName)
    (and (setq s (entsel "\nSelect any object: "))
(wcmatch (setq en (cdr (assoc 0 (setq e (entget (car s))))))
  "LEADER"
       ;; This group of settings are common to all objects
       ;; layer
       (setvar 'CLAYER (cdr (assoc 8 e)))
       ;; linetype
       (if (cdr (assoc 6 e))
(setvar 'CELTYPE (cdr (assoc 6 e)))
(setvar 'CELTYPE "ByLayer")
       ;; color
       (if (cdr (assoc 62 e))
(setvar 'CECOLOR (itoa (cdr (assoc 62 e))))
(setvar 'CECOLOR "ByLayer")
       (if (wcmatch en "LEADER")
   ;;convert to vl object
   (setq vla_s (vlax-ename->vla-object (ssname s 0)))
   ;(setq vla_s (vlax-ename->vla-object s))
   (princ "\nfinally!")
   (setq LeaderName (vla-get-ArrowheadBlock vla_s))
   (setvar "DIMASZ" 0.125)
   (command ".QLEADER" pause pause pause)
   (command ".TEXT" pause)
   (vla-put-ArrowheadBlock (entlast) LeaderName)
     (prompt
       "\nObject is not a LEADER."
ribarm
  • Marko Ribar, architect
Re: vla leaders
« Reply #1 on: October 29, 2015, 03:35:32 PM »
Try to change :
To this :
(setq vla_s (vlax-ename->vla-object (car s)))
M.R. on Youtube
chauhuh
Re: vla leaders
« Reply #2 on: October 29, 2015, 04:26:51 PM »
Your a BOSS! Thank you for the prompt reply.
