Author Topic: Emulate the Color command with DCL  (Read 5914 times)
Prickle Farmer
  • 35+ years of AutoCAD / BricsCAD
« on: October 26, 2015, 11:36:56 PM »
Is anyone aware of a DCL to emulate the Select Color dialog (index Color tab only) that comes up when the Color command is issued?  Why is there not a getcolord lisp command similar to the getfiled command.  This would be a handy interface tool but its a mountain of work to attempt.
I'd rather have a bottle in front of me than a frontal lobotomy.
Re: Emulate the Color command with DCL
« Reply #1 on: October 27, 2015, 12:26:12 AM »
Try
  1. (setq theColorIWant (acad_colordlg 42) )
or
  1. (setq theColorIWant (acad_truecolordlg 42) )
Prickle Farmer
« Reply #2 on: October 27, 2015, 12:51:08 AM »
Awesome!!! :-) :-) :-) :-) :-) :-) :-)
I sure that wheel had been invented just couldn't find it.
Thanks Kerry
