Author Topic: get xref path  (Read 8614 times)
danny
get xref path
« on: May 04, 2005, 07:59:56 PM »
need some help or direction
trying to find a way to get the path of a selected xref?
thanks...
get xref path
« Reply #1 on: May 04, 2005, 08:46:22 PM »
Have a look at this fine piece of work by MP.
http://www.theswamp.org/phpBB2/viewtopic.php?t=3816
danny
get xref path
« Reply #2 on: May 04, 2005, 08:58:41 PM »
Thanks Mark, MP
I'll take a look at it.
pmvliet
get xref path
« Reply #3 on: May 05, 2005, 10:58:45 AM »
Not sure what you are looking for, but keep Reference manager in mind. It has some kewl things and also lets you move path's of referenced items.
for 2k2 it is in the extensions, for 2k4 and above it is installed with the program.
Pieter
danny
get xref path
« Reply #4 on: May 11, 2005, 11:10:43 PM »
Mark/MP or anyone else,
I've taken a look at MP's function and I'm trying to disect it to find exactly what I need, but all I've gotten so far is a headache.
What I'm trying to do is create a lisp that will open a selected xref file.  In order to do that i have to get its path.  File size, Flags, or Count is not needed.
I do use refedit, but in some cases an actual opening of the file is neccessary.
nivuahc
get xref path
« Reply #5 on: May 12, 2005, 12:10:57 AM »
Have you tried the XOPEN command?
whdjr
get xref path
« Reply #6 on: May 12, 2005, 08:24:54 AM »
(defun *ssnames* (selection_set / num lst)
  (repeat (setq num (sslength selection_set))
    (setq num (1- num)
 lst (cons (ssname selection_set num) lst)
  lst
(defun *dxf* (gcode elist)
  (cdr (assoc gcode elist))
(defun remove2 (ss)
  (vl-remove-if-not
    '(lambda (x)
       (= (logand (*dxf* 70
(entget
  (tblobjname "block" (*dxf* 2 (entget x)))
 4
 4
    ss
(defun c:xref_tools (str / sel len obj path pos name ent)
  (setq sel (ssget '((0 . "INSERT"))))
  (if sel
    (and (setq sel (*ssnames* sel))
(setq sel (remove2 sel))
(foreach ent sel
  (setq ent (entget (tblobjname "block" (*dxf* 2 (entget ent)))))
  (setq path (*dxf* 1 ent))
  (cond ((eq str "open")
 (command "vbastmt"
  (strcat "AcadApplication.Documents.Open \""
  path
(T
 (setq pos  (vl-string-position 92 path nil T)
name (substr path (+ 2 pos))
pos  (vl-string-position 46 name 0)
name (substr name 1 pos)
 (command "_xref" str name)
Put all this in the same file.  Load it.
Usage:
(c:xref_tools "open")  ---> Opens the selected xrefs.
(c:xref_tools "reload")  ---> Reloads the selected xrefs.
(c:xref_tools "detach")  ---> Detaches the selected xrefs.
**disclaimer** --> These were written and tested for AutoCAD 2000.
Hope this helps,
get xref path
« Reply #7 on: May 12, 2005, 08:46:29 AM »
Quote from: danny
Disect it?
Maybe you can better define what mean "The path of a selected xref". How are you selecting it?
But to push forward with an attempt to help (as questionable as that may be before my first coffee) ...
If you load up my utility you might call / invoke it like this:
(GetXrefsProperties
    (vla-get-activedocument
        (vlax-get-acad-object)
It might return the following data --
(   (   "Taisei Detail Plan"
        "C:\\ACAD2006\\SAMPLE\\TAISEI DETAIL PLAN.DWG"
        44
        1
    (   "Taisei Door Window Sheet"
        "C:\\ACAD2006\\SAMPLE\\TAISEI DOOR WINDOW SHEET.DWG"
        44
        1
    (   "Taisei Interior Elv"
        "C:\\ACAD2006\\SAMPLE\\TAISEI INTERIOR ELV.DWG"
        44
        1
There are 3 items in the list. Each Item is also a list itself. The first item is the xref name, the second the path, the third the flags* values, and finally the forth is the tally of the number of instances of said xref (normally 1).
So, let's say I "picked" the xref "Taisei Detail Plan" and I wanted the path for it:
(cadr
    (assoc
        (GetXrefsProperties
=> "C:\\ACAD2006\\SAMPLE\\TAISEI DETAIL PLAN.DWG"
Hope this helps.
*Flags is the bitcoded value associated w/dxf group 70, please see the dxf reference.
nivuahc
get xref path
« Reply #8 on: May 12, 2005, 09:53:33 AM »
(vlax-get-property (vlax-ename->vla-object (car (entsel "\nSelect XREF: "))) 'Path)
nivuahc
get xref path
« Reply #9 on: May 12, 2005, 10:03:07 AM »
Don't have the XOPEN command? That's okay, using the technique in Will's code and the above, here's one that works just fine in AutoCAD 2002 (no error checking)
(defun C:XOPEN (/)
  (command "vbastmt"
  (vlax-get-property
    (vlax-ename->vla-object (car (entsel "Select XREF for Editing: ")))
    'Path
get xref path
« Reply #10 on: May 12, 2005, 11:02:25 AM »
Ok, Mr. Slow guy here. :roll:
Given this --
(defun GetXrefPath ( ename / object )
        (   (and
                (eq 'ename (type ename))
                (eq "AcDbBlockReference"
                    (vla-get-objectname
                        (setq object
                                ename
                (vlax-property-available-p object 'path)
            (vla-get-path object)
Try this --
(defun c:XOpen ( / path )
    (if (setq path (GetXrefPath (car (entsel))))
        (if (zerop (getvar "sdi"))
            (vla-open
                (vla-get-documents (vlax-get-acad-object))
                path
            (vla-sendcommand
                (strcat ".open " path "\n")
Cheers.
nivuahc
get xref path
« Reply #11 on: May 12, 2005, 11:22:14 AM »
:P
danny
get xref path
« Reply #12 on: May 12, 2005, 02:07:08 PM »
sorry guys,
I think you all wake up a lot earlier than me..
no, I didn't know that was available.  :oops:
(GetXrefsProperties
This was what a was trying to work with and I can see now, from your routines, how it works.
Thanks for helping me understand.
Hopefully I can krank this stuff out by myself one day...
get xref path
« Reply #13 on: May 12, 2005, 03:06:45 PM »
Our pleasure, come back when you're plate empties.
danny
get xref path
« Reply #14 on: May 17, 2005, 05:29:57 AM »
o.k, my plates empty...or should I say full, I just don't know how to use my utensils to eat.
I was using the xopen to rename some bad filenames but completing the task at hand has become  quite a burden..  I have 150 sheets and I need to find out what xrefs are in the sheets, and rename them.  I've been looking around and found a clip from Smadsen.http://www.theswamp.org/phpBB2/viewtopic.php?t=3083&highlight=xref
got some really long file names that need to be simplified.  I would post some of them but I'm at home right now.  But their way past 30 characters long and its driving me insane.  I know I can change the path using reference manager, but the name?
