Thanks of the follow-up. The CMake approach looks like a departure for Visual Studio's
csproj projects? That's not a direction I'm currently interested in going. I really like Visual Studio hence my latest approach to clone the code between projects inside the IDE, if you change the code in one project it changes for all of them, although you need to add and remove any "universal" files from the original project which could be a pain-point if you stray from the original source project. The only reason I expect to be editing code in target projects is to fix any differences in code between the various APIs or to fix failing unit tests (after I fix CADtest). I also like seeing in the IDE what code the
#if directives are affecting and what API classes are actually being called. Yes, I like having my hand held.
![Smiley :)](http://www.theswamp.org/Smileys/black/smiley.gif)
If CMake does embrace
csproj then it looks a bit like the proliferation of project imports I wrote about at
http://www.theswamp.org/index.php?topic=41868.msg497509#msg497509 which eventually breaks for me because importing a project drags in framework and build settings, References as well as any Nuget package specifics. It also tends to bury things a bit too deeply to quickly make sense of them, especially if I am coming back to something I haven't looked at for quite a while. I have zero experience with CMake so I may be way off the mark here.
The Git approach has potential but does this mean you need to write the code in a project that doesn't compile (gasp! No Intellisense) and juggle Git Remotes. No, not so hard really but I am trying to keep it all "simple". In theory. Your Git approach works for you perhaps, as you said, because you don't work in Visual Studio?
I also wanted a system I can drop in on top of stuff I've already written without breaking it. You never break the source project because it never writes to it, although your code in it will change with various
#if directives if your platforms vary widely.
This article:
http://haacked.com/archive/2014/04/16/csproj-merge-conflicts/ explains what I mean by .csproj merge conflicts. Understanding what is going on in the
csproj files, and keeping an eye on it is important with this approach. They are just XML text files so the differences will be very obvious in commit diffs but you need to know what to expect. Once you've seen a few sets of changes then you will know what looks odd. Also, reverting changes is easy.
I tested Code Cloner with a WPF AutoCAD Project and it worked well, it all came together, looks good in Visual Studio (hey, I care) and builds fine.
