Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Error after making field, referred to the Xref
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Error after making field, referred to the Xref (Read 2845 times)
frostmourn
Mosquito
on:
September 30, 2015, 11:28:08 AM »
Hello all. I have got a problem during working with external references. Here the file AC-11 was used in the file AC-22 as attached Xref. Then doing the following code in it:
Code - Auto/Visual Lisp:
[Select]
defun
c:
123
LST adoc str_lst
vl-load-com
setq
adoc
vla-get-activedocument
vlax-get-acad-object
vlax-for
x
vla-get-blocks
adoc
if
equal
vla-get-isxref
x
:vlax-true
setq
LstXref
cons
x LstXref
foreach
x
get
block
contents
car
LstXref
if
wcmatch
vla-get-objectname
x
"*Text"
setq
LST
cons
x LST
setq
str_lst
mapcar
lambda
x
LM:ConstructFieldString x
"TextString"
LST
foreach
x
sstolist_vla
ssget
"_X"
8
"Specification"
0
"TEXT"
vla-put-textstring
x
car
str_lst
setq
str_lst
cdr
str_lst
x
vla-regen
adoc acActiveViewport
;; LM:ConstructFieldString
lambda
vl-load-com
if
null
acdoc
setq
acdoc
eval
list
defun
'LM:ConstructFieldString '
ent prop format
ent
list
if
'ent
list
strcat
AcObjProp Object(%<
_ObjId "
if
and
vl-string-search
"64"
getenv
"PROCESSOR_ARCHITECTURE"
vlax-method-applicable-p
vla-get-utility
acdoc
'getobjectidstring
list
'vla
getobjectidstring
vla-get-utility
acdoc
'ent '
:vlax-false
itoa
vla-get-objectid
ent
'prop '
if
not
eq
format
strcat
f
format
defun
sstolist_vla
ss
i lst
setq
i
0
if
ss
repeat
sslength
ss
setq
lst
append
lst
list
vlax
ename
vla-object
ssname
ss i
i
1+
i
;end of repeat
lst
defun
get
block
contents
ent
def res _kpblc
conv
vla
to
list
; exam: (get-block-contents (car (entsel "\nВыберите блок")))
defun
_kpblc
conv
vla
to
list
value
res
cond
listp
value
mapcar
function
_kpblc
conv
vla
to
list
value
type
value
variant
_kpblc
conv
vla
to
list
vlax
variant-value
value
type
value
safearray
if
vlax
safearray-get-u-bound
value
1
0
_kpblc
conv
vla
to
list
vlax
safearray
list
value
;_ end of if
and
type
value
vla-object
vlax-property-available-p
value 'count
vlax-for
sub value
setq
res
cons
sub res
;_ end of vlax-for
t value
;_ end of cond
;_ end of defun
cond
and
ent
type
ent
'ename
cdr
assoc
0
entget
ent
"INSERT"
;_ end of and
setq
res
get
block
contents
vlax
ename
vla-object
ent
and
ent
type
ent
vla-object
wcmatch
strcase
vla-get-objectname
ent
"*BLOCK*"
setq
def
vla-item
vla-get-blocks
vla-get-document
ent
vla-get-name
ent
setq
res
; (list
lambda
_lst
vlax-for
subent def
setq
_lst
cons
subent _lst
reverse
_lst
; (_kpblc-conv-vla-to-list (vla-getattributes ent))
; (_kpblc-conv-vla-to-list (vla-getconstantattributes ent))
; ) ;_ end of list
;_ end of cond
res
As a result we are obtaining a list of field codes, refering to the text entities on a specified layer in the Xref. And now if we paste codes to the texts in AC-22 trying to make working field, then after saving drawing will constantly get an error window - "recommended to do RECOVER procedure" (don't remember right wording).
I have tried to paste only textstrings; to process a simple block instead of Xref - all is good. Also tried using of Acad2016, saving in old versions, no matter. After re-opening file works correctly, audit shows 0 errors. Fields are the necessary condition here.
Can anybody give a solution or explanation at least? Will be happy even could to set off an error window.
System - Autocad 2010 x64 sp3 rus, SPDSGraphics 8.0, windows 7 pro x64 sp1. Thanks in advance.
Sorry for probably mistakes.
Logged
Needs a day job
Re: Error after making field, referred to the Xref
Reply #1 on:
September 30, 2015, 11:43:13 AM »
Not related to your code but ... first thing I see you should not be doing is putting special characters in your file names.
This is the dl'd file I see .. something weird going on.
Logged
frostmourn
Mosquito
Reply #2 on:
October 01, 2015, 04:24:14 AM »
Hmm, very strange... I see ordinary letters. It's something related with cyrillic encoding, I think.
Ok, here are files with only numbers using (by the way, it had no effect according to my problem...).
Last Edit: October 01, 2015, 04:32:12 AM by frostmourn
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
