Author Topic: xref  (Read 2263 times)
Fabricio28
xref
« on: September 21, 2015, 02:10:48 PM »
Hello everybody,
I'm trouble with a reference project. Everytime I open the drawing, can't located or read the main file.
I don't know what happening, I have to reload to fix it.
Re: xref
« Reply #1 on: September 21, 2015, 02:16:04 PM »
Suggest use RELATIVE Path when attaching
Rob...
Re: xref
« Reply #2 on: September 21, 2015, 02:16:54 PM »
That happens when either the name or the location of the XREF changes, when using absolute pathing.
It can also happen if the location of the referencing file changes.
Are you saving the drawing after repathing the XREF?
CAD Tech
Fabricio28
Re: xref
« Reply #3 on: September 21, 2015, 02:26:09 PM »
Wow great!!
Thank you.
Fabricio28
Re: xref
« Reply #4 on: September 21, 2015, 02:26:52 PM »
Yep, I'm saving.
I was using full path instead of relative path. What is the difference?
Rob...
Re: xref
« Reply #5 on: September 21, 2015, 02:29:26 PM »
Look at the path displayed when you switch to relative. It does not have the entire path. It paths the XREF in relation to the referencing file. If you are not moving or copying the files, it shouldn't make any difference but relative pathing is usually preferred.
CAD Tech
Fabricio28
Re: xref
« Reply #6 on: September 21, 2015, 02:33:21 PM »
Great!  :-D
Thanks Rob and Michael!
